Author Topic: Gasket Scan Library  (Read 24764 times)
Offline Hoosier Daddy
  • Earache my eye...
Gasket Scan Library
« on: Dec 30, 2012, 07:55:22 »
A member on another forum posted life sized scans of his gaskets. I thought it would be a great idea to start a library of scans for DIY'ers to use as templates for making their own. Since many have access to flat bed scanners either at home or at work, and we have such a diversity of engines here, I hope this will grow to be quite extensive. Next time you buy a gasket or set simply scan it and post it up here.
I started the list off with the 76 SOHC CB750 units he submitted and I just picked up the OEM Alternator Cover, Clutch Cover, Left Crankcase, and Oil Pan gaskets for my  DOHC engine from Mother Honda. They might just all fit on my 8 ˝ X 11 flatbed scanner... I'll be scanning them and adding to the list before installing soon.
List the year, make, and model at the begining of the post, if you can add the actual OEM part number (not aftermarket) onto the scan itself. That will make it easier for others to find their applications.
I will try to maintain a list here of what has been added with shortcuts to that post.
76 HONDA CB750F
74-76 HONDA CB360
71 HONDA CB450 (Vesrah gasket kit)
« Last Edit: Feb 02, 2013, 08:52:12 by Hoosier Daddy »
STAY CLEAN '67 BSA Spitfire
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
NO CLASS '72 CB450 K5
  • Earache my eye...
Re: Gasket Scan Library (sticky?)
« Reply #1 on: Dec 30, 2012, 07:58:24 »
'76 Honda CB750F
CB750 Gasket set 1
*Note* These are on 11x17 (ledger) size pape
https://docs.google.com/file/d/0BwBS3wzPowkydjF1Z09MUVJyb3M/edit?pli=1
CB750 gasket set 2
https://docs.google.com/file/d/0BwBS3wzPowkyQWliWE01X2xUa2c/edit?pli=1
« Last Edit: Dec 30, 2012, 08:01:25 by Hoosier Daddy »
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
Offline VonYinzer
« Reply #2 on: Dec 30, 2012, 08:09:39 »
Very cool idea. I have an R5 gasket kit en route. Ill find someone to scan them for me. All three of them. Haha.
Offline notlob
  • Made in England
    • CB750 Brat Bobber Build Thread
« Reply #3 on: Dec 30, 2012, 08:26:54 »
Might be a good idea to include the model year in the description to aid searches.  cb750F 75-78 or cb750F 79-82
“Every time I start thinking the world is all bad, then I start seeing people out there having a good time on motorcycles. It makes me take another look.” >> Steve McQueen
Look at it! God, your project is ... it's everywhere. Your garage looks like you've been committing war crimes against a robot.
Build Threads
1980 Cb750: http://www.dotheton.com/forum/index.php?topic=43860.0
1982 CB900: http://www.dotheton.com/forum/index.php?topic=46733.0
  • Earache my eye...
« Reply #4 on: Dec 30, 2012, 08:33:06 »
YES!
As long as the poster lists it I'll include it in the description... since I don't want to be responsible for application cross-referance.
As I said, I know mine will fit 79-82 DOHC CB750 (all) and will list them that way once entered... but as for the original listed 76 CB750F I didn't want to risk including a wrong model or year so I left it as submitted. ;)
Also found info on "Google Docs" to store and share .PDF's at  http://support.google.com/drive/bin/answer.py?hl=en&answer=2424384
« Last Edit: Dec 30, 2012, 09:15:19 by Hoosier Daddy »
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
Offline AlphaDogCustoms
  • Science is true whether you believe in it or not.
    • Alpha Dog Customs
« Reply #5 on: Dec 30, 2012, 09:42:00 »
I've always wished that I have a large scanner and a vinyl cutting machine to make custom gaskets. I work with oddball vintage bikes often enough that gaskets can sometimes be difficult to get. I am not interested in the labor intensive process of manually cutting out gaskets, but if I could have a computer controlled cutter/plotter do it, I would be like a pig in shit!
...every dump I take is original too, and it doesn't smell any better because of it's originality.
Alpha Dog Custom Cycles
Painting
Powdercoating
Custom Fabrication
Repairs
I'm so old, I even know what ignition points are.
Offline RoadRash
« Reply #6 on: Dec 30, 2012, 12:27:09 »
This could be a great resource. I hope it takes off. Just got some fresh gaskets for my 78 GS750. May have to scan and submit them.
  • Earache my eye...
« Reply #7 on: Dec 30, 2012, 12:54:03 »
Please do RoadRash!
And yes AlphaDog, if I could just load gasket paper in my printer I'd be happy!
« Last Edit: Dec 30, 2012, 12:56:01 by Hoosier Daddy »
ROCK-IT '81 CB750C
BOMBER '81 GL1100
OVERKILL '80 GS750
Offline Worst cb650 ever
  • You can always get it running with time or money.
« Reply #8 on: Jan 27, 2013, 21:30:51 »
Hey Hoosier,
I think maybe you found my post over on hondatwins - I post as "CB650" there.  I'm trying to find a good way to share the PDF I created, but in the meantime here's a link to my post.  Feel free to throw it up on your Google docs.
1974 - 1976 CB360 gaskets
http://www.hondatwins.net/forum/viewtopic.php?f=43&t=20248
DTT Blue (cause Winter is Coming) CB360 Club.
1995 CBR900RR - a winter flip not worth a DTT writeup - Sold
1986 Yamaha SRX600 - mailed to me from California - build coming soon?
1983 VF750F
1976 CB360T
1993 CBR900RR - Sold
1979 CB650 - Sold
Offline Ncstatecamp
« Reply #9 on: Feb 01, 2013, 22:46:29 »
'76 Honda CB750F
CB750 Gasket set 1
CB750 gasket set 2
would these be the same as a 750k?
