Author Topic: CB 650 Oil Leak - Should I be worried?  (Read 3911 times)
Offline akasoldats
« on: Jan 07, 2013, 21:25:14 »
So my 1980 cb 650 has had an oil leak pretty much since I purchased it. Yesterday I finally figured out where its coming from, the only problem is I don't know what the part is. I've attached a picture of the area that is leaking. I'm not sure if there is supposed to be a gasket between the cover and the part but it drips. It only leaks a drop or two once the engine heats up. Is this something I can just rtv? Get a gasket if one exists? Or should I just replace the whole unit? I wanted to take the whole cover off but I assumed there is probably more oil in there and I dont have anymore to refill it atm.
1980 CB 650 Custom
I just wanna go fast.
Offline jay_kent
  • 1979 cb650
    • Cafe build blog
Re: CB 650 Oil Leak - Should I be worried?
« Reply #1 on: Jan 07, 2013, 22:01:29 »
There's an o-ring in there that'll you want to replace. No.13. 46mm
It's located at the back of the oil pump between the case and the pump as far as i remember.
DTT build thread - here
More pics at my Cafe build blog - Here
"And yeah David...you're pretty much bugshit nuts just like the rest of us." ~Swagger
Offline blackbuddha1
  • 79 CB650-74 BMW 60/6
« Reply #2 on: Jan 08, 2013, 00:17:47 »
almost every daily rider marks it's territory.......i add a little oil to my cb650 every week but it does have almost 28k on it and it's only 34 years old
Offline jay_kent
  • 1979 cb650
    • Cafe build blog
« Reply #3 on: Jan 08, 2013, 13:52:41 »
True that, my left leg on my a few pairs of jeans bear the mark of a leaky top. Still runs great though
Offline akasoldats
« Reply #4 on: Jan 10, 2013, 21:09:00 »
Good to know. I was just a little worried I guess since I didn't know if that meant my oil pump was on its way out.
1980 CB 650 Custom
Offline akasoldats
« Reply #5 on: Jan 14, 2013, 15:38:03 »
Anyone know where I can order one. I went into honda and showed him what I needed but he informed me the part has been discontinued..
1980 CB 650 Custom
Offline VonYinzer
« Reply #6 on: Jan 14, 2013, 15:47:07 »
Find the dimensions of the oring and order it through mcmaster carr.
As far as all bikes marking their territory... That's not true. All leaks can (and should) be fixed if the owner is willing to do the work. They didn't (mostly ;) ) leak when new so they shouldn't leak now.
Offline akasoldats
« Reply #7 on: Jan 17, 2013, 18:32:03 »
Any idea how I can find the diameter and the o-ring type with out actually removing it from the bike? Its currently my dd, and I get the feeling it will probably disintegrate when I take it off. Who knows if its ever actually been swapped out.
1980 CB 650 Custom
Offline Mydlyfkryzis
  • 当有疑问时踢你的敌人在生殖器上,你可以道歉后
    • CB360 Build
« Reply #8 on: Jan 21, 2013, 00:37:19 »
From a Honda microfiche (Houseof honda.com)
O-RING (46X3)
91309-703-000
Go to the O-ring Store : http://www.theoringstore.com/index.php?main_page=product_info&cPath=368_12_46&products_id=2120
$0.84 each  Shipping is more.
Go to http://www.houseofhondaparts.com/fiche_select2.asp?category=Motorcycles&make=Honda&year=1980&fveh=132942
Find some more 0-rings you need and order from the o-ring store. The shipping on one o-ring is higher than the o-ring, so pick up a couple and it will be a good deal.
There are 10 kinds of people, those who know binary and those who don't
Ignorance is bliss....and there are a lot of happy people out there!
AlphaDogChoppers: "A friend of mine once said, "There's no such thing as a stupid question, but there sure are a lot of inquisitive idiots."
"if you need a hammer to do something...  you are probably doing it wrong" - LazloH
DTT Blue CB360 Club - We discriminate!
Mydlyfkryzis = Mid Life Crisis
1991 Honda Nighthawk 750
1976 Honda CB360t
http://www.dotheton.com/forum/index.php?topic=41649.new#new
Offline akasoldats
« Reply #9 on: Feb 28, 2013, 21:40:45 »
So I finally got around to changing the o-ring last weekend.. It took a bit to get those godforsaken phillips screws out. I hope to replace them soon. Anyways, after I swapped out the o-ring and put everything back together the sob still leaked.. is it possible that the #12's & #14's in the post above need to be replaced too or at this point should I start looking for another oilpump?
1980 CB 650 Custom
