Author Topic: 1972 DS7 The Row Boat  (Read 78934 times)
Offline clem
  • static fluff
« on: Feb 03, 2013, 22:13:26 »
I recently purchased an old smoker in semi rough shape. It looked like the perfect candidate to try and pull off a cafe type build so here I go.
 When I first got the bike home I checked it out for spark. Fail. Step two, inspect the wire harness, looks like the regulator is missing. Damn! I then pulled the oil tank off and drained it. Water came out first then oil. This is starting to look like a challenge;)
The bike seems to have very good compression but I have not tested it with a gauge at this point. I did order a new regulator and now I'm contemplating trying to at least get a spark going or just take the motor out now and start rebuilding it. It'll get rebuilt no matter when it comes out but I'd like to see if I can at least get it to make some kind of noise and smoke.
Overall, I'd like the bike in a yellow and black scheme like the late seventies/early eighties motocross bikes. I may do a front end change depending on costs and I'll take a swing at making the seat for it. I don't have the stock tank for it but I was planning on putting a RD400 tank on it. If anyone has one laying around hit me up cause I'd rather pass some cash to someone on here if possible. I'm already thinking about 350 cylinders with the reeds and some decent chambers, I really dig the bare cone pipes. I'll be looking for some good input from here along the way.
The points don't look good either:
Did I mention that it doesn't shift through the gears either? Lol
Good News:
The blinkers and tail light work!
« Last Edit: Jan 25, 2014, 22:17:38 by clem »
Offline VonYinzer
Re: 1972 DS7 The Long Road
« Reply #1 on: Feb 03, 2013, 22:44:59 »
Nice! You'll love it. In that condition I'd suggest a complete teardown and rebuild. All new seals and gaskets are a must. No point in trying to get it running as is. Rebuild to spec and go from there. Trying to force it now could damage some internals.
If you're ditching that RD tank, let me know. I could use it
When the time comes, hit up BradJ here on DTT for chambers.
Other than the motor rebuild everything on these bikes is super simple. If you have any questions let me know. If I can help, I will.
Offline clem
  • static fluff
« Reply #2 on: Feb 03, 2013, 23:03:27 »
Von, I think your right. With it not being able to shift through the gears I'd hate to have something loose or broken off and go spinning around in there. The last two stroke that I tore down to the crank was an 89 CR125 that Iseized the lower rod bearing on so it's been awhile. Looks like it's time to strip it down.
Offline clem
  • static fluff
« Reply #3 on: Feb 03, 2013, 23:10:13 »
Oh and yea, the tank is yours. Just pm me what you think is fair.
Offline bradj
« Reply #4 on: Feb 03, 2013, 23:11:39 »
Between me and von we got seveal 5 speeds if you have trans problem we got ya covered
Offline VonYinzer
« Reply #5 on: Feb 03, 2013, 23:15:41 »
Yup.
Offline clem
  • static fluff
« Reply #6 on: Feb 07, 2013, 12:24:25 »
Just to give an update, I bought a RD400 tank and a set of rearset from a R6(took the tip from Redbird's build). The fork legs are shot, they don't have pits in them it's more like canyons. Looking at Franks it would run about $297 + any seals, oil, etc. so I'm looking at a front end from either an EX250 or FZR600. I haven't done any research yet to see which one might be easier but I'm thinking that they both may prove to be a little work. I'm open for suggestions on the front end and I'll post some more pics when I get time to continue the dismantling.
Offline VonYinzer
« Reply #7 on: Feb 07, 2013, 13:24:50 »
If you can get FZR forks, do it. You can run an FZR rotor up front with an offset. Brad fan share more detailed info as he's done this all before.
Offline clem
  • static fluff
« Reply #8 on: Feb 07, 2013, 16:08:04 »
Cool, I never really cared for Kawasaki anyway. If Brad lays out the plan, will it include mashing things with a hammer? ;D
Offline bradj
« Reply #9 on: Feb 07, 2013, 23:07:24 »
Ez does it . yo i got one ugly ex500 front end ill sell cheap i also got most of a fzr front end that already has a rd stem swapped into it that ill mabie sell
