Re: 1993 Suzuki GN250 Tracker
Instead of the original 315mm rear shocks, I ordered 365mm that will straight the way it looks.. there's going to be a problem with the rear brake lever, as well as the muffler bracket, I'll get to that when I'll get the shocks.
Front End is out, in order to replace oil seals and to replace the dust covers with more appropriate ones:
Exasust wrap... just because...
Ducati Darmah's front fender will do the work as the new rear one, it's made of Stainless steel so I'll polish it once ready
Current seat - out... needs to be replaced with a flat one
Leftovers..
The fuel tank angle should be aligned with the frame, so I used spacers for that in order to get rid of the 'custom' look
The triangle should be cleaned... meaning, no battery (small anti-gravity once will replace the old one in a different location, TBD)
starting to work on the new seat base
alignments
Starting to look as I wish it would look...
Front fender chopped a little... or more than a little...
I replaced the muffler with a chopped one of a Ducati 900SSD, the sound it makes now is ^%@5&* amazing!
