Author Topic: Dominator NX650 Street tracker  (Read 13192 times)
Offline Torker1
Re: Dominator NX650 Street tracker
« Reply #10 on: Mar 06, 2013, 04:35:56 »
Thanks for all the positive comments !
The rear shock will be replaced with a Hagon fully adjustable, which I will stiffen up and fit with a bump stop on the shaft to stop excess travel. Thanks for the tip about dirt track cars as a supplier for the rubber :) . Exhaust will use a standard front section, mated to a megaphone silencer through a joining section that I will need to fab.
The front wheel uses the standard hub laced to an 18" rim from the rear of an XR250. It was hard to source as the Hondas have an unusual amount of spokes.
I took it to a wheel builder to lace up, but frankly it was only just do-able as the shorter spokes had to be flexed to follow a path to the rim. One really important thing to be aware of is that the hub is not necessarily centred with the rim and you will need to know the offset. I can look it up and pass it on if you need it.
Cheers , Phil
Offline Cuba Libre
« Reply #11 on: Apr 01, 2013, 10:55:09 »
What is the tank off?
M.
Offline Bert Jan
  • Holy Modification Batman
    • Outsiders Netherlands
« Reply #12 on: Apr 15, 2013, 20:52:38 »
Cheers , Phil
We (Bons and I) got the spokes in for the front wheel. If you could look up the offset, it would be much appreciated. I could do it in the forks i guess, but i like to do it the way it's done. Not how it can be done. Thanks!
Offline Bert Jan
« Reply #13 on: Jun 29, 2013, 20:58:07 »
Yooooo any updates??
Offline Bert Jan
« Reply #14 on: Jul 11, 2013, 06:49:35 »
Updates please!!
Offline CafeRacersUnited
  • CafeRacersUnited.com
    • http://www.caferacersunited.com
« Reply #15 on: Aug 12, 2013, 12:24:59 »
Still working on it?
Working on a NX650 as well :)
http://caferacersunited.com/nx650-project
Curious about any progress!
Offline Bert Jan
« Reply #16 on: Aug 12, 2013, 13:45:36 »
Check my Gf's build, she is doing an NX too. Its somewhere in the trackers section. Her username is Bons.
Offline Torker1
« Reply #17 on: Sep 06, 2016, 13:02:37 »
Update coming soon.
Offline Torker1
« Reply #18 on: Sep 06, 2016, 13:16:22 »
Thread returns from the grave !
Offline Torker1
« Reply #19 on: Sep 06, 2016, 13:17:26 »
Another pic.
