82 KZ750 LTD Brat Style Build **UPDATED**
Re: 82 KZ750 LTD Brat Style Build - First Timer
having a weird problem with the blinkers, can't get them to blink lol. They turn on and stay solid on both sides.
Are they LED, they look it, if so did you replace your flasher relay with an Electronic one for LED's? If not your old one won't work, not enough load/draw from the signals.
Correct, I just picked up a new one as my electronic one went kaput. You can use either of these styles as long as they are the digital/electronic. Thermal are the normal ones.
Examples:
Okay, still check the flasher relay. If it's okay then check your switch on the controls for continuity.
Been puttin some miles on. Happy Easter!
Nice. Thought about some shorter stainless brake lines?
Sent from my SPH-L710 using Tapatalk
I bought one to try on for size, its in the works.
Looks good! Any idea about the comfort factor? Now we need some photos with you on it!
Its pretty comfy for this style seat, its got 3 layers of high density yoga mat and a little layer of soft foam.
Started playing around with some pipes my buddy had laying around from his cm400. Cut out the baffle, chopped some off and mounted. I think it looks pretty damn good.
So I was having an issue with the automatic timing unit, took it apart to clean and found out it was seized. After a lot of heat and some pb blaster, it came loose. Now I just need to relube and refit, should feel like a new bike. I don't think it's ever functioned properly since I've owned it.
So I'm still trying to perfect this thing. Latest project has been my tank, gold was alright in pictures but it was just plastidip and gas killed it. Refurbished the tank badges...time consuming but well worth it.
More updates, those badges were done to put on my freshly painted tank. Other new stuff, yellow headlight film, bar end mirror to replace the old mirror, led rear blinkers / electronic blinker flasher to replace the bigger filament style, tach and speedo, fork gaiters, and new spacers for the front forks to lower it a bit. I'm in love again... for now.
Looks good! All the finer details at the end of the day make the bike IMO
Handlebars look nice and clean, mind giving us a run down on what you've used
Sure, I think this covers it.
Chrome superbike bars from dime city
OURY grips from z1
ZX7 master cylinder
Bar End mirror from Amazon
Stock handlebar controls
OURY grips from z1
ZX7 master cylinder
what throttle body and cables are you running?
