Maineiac
Mainely A Dream
1972 CB750K2
Engine:
Rebuilt with all new gaskets & seals
836cc Wiseco Big Bore Kit
Web Grind Cam
New valve springs
New tappets
Stainless hardware kit
Mikuni RS34 Flatslide Carbs
Dynoman pod filters
New carb isolators & clamps
Yoshi style 4 into 1 exhaust
New Motion Pro throttle cables
Dyna 2K Electronic Ignition
Cycle-X points cover
Dyna 3 ohm coils (w/resistors)
New plug wires/NGK iridium plugs
New Motion Pro clutch cable
Custom oil tank & lines
Frame:
Eastwood Chassis Black 2K ceramic paint in Satin
Shaved mounting tabs
Removed center stand & bracket
Gusseted and smoothed
Welded kick-up tail section
Bronze swingarm bushings
Tapered steering bearings
Dresda style boxed swingarm
New lower shock bushings
Cycle-X billet triple trees
Tarozzi modified clip-ons
Gauges/Electrical/Lights:
Rewired bow to stern
Custom electrics box
Rick's solid state reg./rect.
Earth-X Lithium Battery
5-3/4" Bates Halogen Headlight
Joker Machine Taillight
Acewell digital tach./speedo.
Innovate Wideband O2
External oil pressure gauge
New start solenoid & fuse block
Suspension:
New Cycle-X early style forks
New fork caps
T-Kat fork brace w/satin powder
New fork seals & gaiters
Slightly polished fork lowers
Progressive fork springs
Hagon Slimline rear shocks
Brakes:
Dual disks lightened &drilled
New Tracker style master cylinder
New stainless lines & alloy tubing
New stainless caliper pistons & seal
New EBC brake pads
New bleed valves & caps
Calipers powdered satin
Wheels:
Excel front 1.85"x19" alloy rim
Excel rear 2.25"x18" alloy rim
New tubes & rim strips (duh)
New wheel bearings
Powdered satin spokes
Avon Roadrider tires 3.25"/4.00"
Slightly polished hubs front & rear
Bodywork & Upholstery:
'78 Supersport Tank
Muscle Car hood pin gas cap
House of Kolor Maroon Metallic
Eastwood Satin Black 2K accents
Custom seat & pan
There's still some gloss pin striping to do and gloss letter faces, but otherwise, she's pretty well sorted out.
