Author Topic: KZ200 Brat Tracker Build -- "Poor Man's Pine"  (Read 14213 times)
Offline aaronbev79
Re: KZ200 Brat Tracker Build -- "Poor Man's Pine"
« Reply #30 on: May 14, 2013, 21:09:02 »
Covers came out good, i also like the way you made the seat using the stock pan.
Looks like its going to be a bumpy ride tho, i would know because my last bike had 1/2 an inch of foam and then leather to sit on. But as you said, its more than enough for around the town scooting :)
The upholsterer is adding another 1/2" of foam between each of the stitched pleats so that they are more exaggerated--so those should help. And, the spray foam added a lot more cushion than I expected as well. So hopefully it will be comfortable. If not, I may replace the spray foam with more comfortable padding.
Checkout my KZ200 Brat Tracker Build!
http://www.dotheton.com/forum/index.php?topic=48954.0
Offline aaronbev79
« Reply #31 on: May 15, 2013, 13:27:05 »
Seat is finished! When the rest of the bike is blacked out, this is going to offset the black nicely.
Here's the seat when I picked it up from the shop:
Here it is when I got it home and put it on my bike. I really like how the stock pan goes up in the back almost giving it a slight street fighter look. The thickness is perfect. Thick and comfortable enough that it will be great to ride around on, but about half as thick as the stock seat.
Offline aaronbev79
« Reply #33 on: May 15, 2013, 18:08:17 »
That seat is amazing!!!!
Thanks! I like that he added 1/2" of padding between every ripple. It really helped exaggerate the depth of the ripples, and added more padding without making the seat too tall.
The best part is that I didn't spend more than a day on the seat modification. :)
« Reply #34 on: May 15, 2013, 19:03:56 »
It looks perfect. I was checking out the pics of the seat pan, does the back go up like that from the factory or did you bend it up?
Offline aaronbev79
« Reply #35 on: May 15, 2013, 19:38:02 »
Yep--that bend in the back is stock. I did nothing to the seat pan besides the spray foam. We are lucking in that the stock KZ200 pan is great for a tracker/street fighter looking seat. I honestly didn't think it would look that good. I'm excited to see how it looks once I attach the brake light/license plate holder. I'm hoping to angle the license plate so that it gives the appearance of a rear fender.
I've also decided to add a slightly taller shock to the rear of the bike. I have a great used bike shop near my house with all sorts of used parts lying around, so I should have pics tomorrow. I'm hoping to raise the back end 1-2" and lower the front 1" to change the way the bike sits. I want more of a levelled look--similar to a motard/dual sport--and right now with the stock height the front end sits a little too high for my taste.
« Last Edit: May 15, 2013, 22:40:28 by aaronbev79 »
« Reply #36 on: May 15, 2013, 20:00:34 »
Im interested in seeing what you do with the license/light combo. And ya that seat pan is a sweet gift from kawasaki.  I agree with the larger shocks, 1-2"  will get that stance, I just stared looking at beefier tires with an on/off road tread.
« Reply #37 on: May 15, 2013, 20:03:26 »
That white material on the right, whats it called/where would I go to get some just like that?
« Reply #38 on: May 15, 2013, 20:21:16 »
Oh Ya, What are you going to do with the foot pegs and controls? I have left the main pegs off and the bag pegs fit nicely, I think I might design my own foot controls, Have you figured anything out yet or going to use the factory ones?
Offline aaronbev79
« Reply #39 on: May 15, 2013, 22:00:15 »
It's a fake leather/vinyl. I didn't use real leather on my seat because it would've cost twice as much. The guy at the shop had it lying around, but he said if I didn't like the color that I could go to Joann Fabrics or some other local craft/fabric store to find other colors and patterns. Had I bought the material myself, and not opted for hidden/removable snaps under the seat, I could've had the seat recovered for less than $75.
The material in the right in the photo is actually a taupe/greyish color. I ended up going with the tan/saddle color because I thought it would stand out more against the black bike.
« Last Edit: May 15, 2013, 22:06:09 by aaronbev79 »
