Author Topic: USD Fork swap.....what should i make this bushing out of????  (Read 6382 times)
Offline MILLENNIUM FALCON
I am swapping to USD forks and the closest bearing I can find has a 2mm larger inside diameter than the triple tree stem. So i will need to make a bushing to press onto the stem to fit the new bearing. The bushings will be about 17mm in length, (i.d)28mm (o.d) 30mm. I'm just looking for some insight on materials for this bushing. Thank you
Offline fade2nada
    • My photography work - FASHION | PORTRAITS | EDITORIAL | TRAVEL
Re: USD Fork swap.....what should i make this bushing out of????
« Reply #1 on: May 21, 2013, 12:46:26 »
Don't shim anything. Get the right tapered bearings at allballsracing.com
They have a fork conversion page already setup. Easiest part of USD fork conversion process!
Photographer Motorcycle Fanatic James Dean Fan
K5 GSX-R 750 1992 Suzuki GSF-400 Bandit 72 & 75 T500 2STROKE 1979 KZ650D Project Bike
Offline Bozz
    • not nearly cool enough website
« Reply #2 on: May 21, 2013, 12:51:14 »
Machining a bushing seems like more work than machining a new stem for the trees, no?
Cheers!
-Bozz
(All opinions worth less than you paid for them!)
05 FZ6 - 99 ZRX1100 - 93 GSXR750 - 82 GL500 - 78 GL1000 - 77 KZ900 - 77 CX500 - 60 R60
« Reply #3 on: May 21, 2013, 13:34:49 »
Ive spent hours searching and calling. Ive tried all the companies around. the bearing i need doesn't exist.  haha. I tried all balls. I ended up ordering my bearings from them but they are perfect.....but as close as I can get. If you can find it ill order it haha. making this bushing will be very simple. Much less work than a new stem. I was just getting some opinions on what material to make it out of.
Here are the sizes i need.
28x47x15
28x55x17
Offline Tim
  • Administrator
    • DO THE TON
« Reply #4 on: May 21, 2013, 13:57:43 »
I had a similar problem when I modified my late XS650 tree to fit in an earlier XS frame (shorter steering tube on earlier frames).
I had a machine shop remove the stem, and then cut an inch off the bottom and weld it back into place.  Unfortunately we didn't anticipate the bearing seating area being removed in the process, and that left the stem a little small for the bearing in it's new location.
So, the stem came back out, and they added some material to the stem with weld.  Then it was turned on a lathe to the right diameter for the bearing.
Might be an option vs. a really thin 1mm bushing.
Offline hillsy
« Reply #5 on: May 21, 2013, 23:55:44 »
A bushing that thin will more than likely be crushed when you try and press the bearing onto the stem (the bottom bearing at least). You probably need to do a stem swap.
What is the front end off that has the 28mm stem?
« Reply #6 on: May 22, 2013, 02:17:21 »
i just machined the bushing to see what it would look like.....i am confident (fairly haha) that I can press it on there without crushing it. i'm not going to make it quite as tight as the stock bearing. The stem is off of a rm125
!!WARNING STUPID QUESTION!!
why does the lower bearing need to be pressed on TIGHTER than balls but the top bearing just slides right on? It seems to me that if everything is properly fitted and assembled nothing would move even with a slip fit on both bearings. The stem has a cir-clip on the bottom to keep it from pulling through and there is a nut on top to keep it from moving the other way.
Offline hillsy
« Reply #7 on: May 22, 2013, 04:00:04 »
The bottom bearing holds the weight of the motorcycle - the top bearing pretty much just "centres" the stem / top clamp. Any play in the bottom bearing will result in rapid wear / failure.
Offline VonYinzer
« Reply #8 on: May 22, 2013, 10:24:35 »
What Tim said...
Have a shop add material by welding and machine to spec. That bushing will fail.
Offline Tim
  • Administrator
    • DO THE TON
« Reply #9 on: May 22, 2013, 17:27:16 »
The top bearing needs to slide in order to be able to adjust the pre-load on the stack to eliminate slop in the stem, and to make it possible to assemble/disassemble without tools.  If the upper bearing was pressed into place, it would basically be impossible to take the front end off.
The press fit lower bearing is presumably better than having it a slip on fit as it takes the brunt of all the vibration/impact etc. and any slop between the stem and bearing would ultimately lead to a nasty catastrophic failure of some form.
