Author Topic: USD Fork swap.....what should i make this bushing out of????  (Read 6218 times)
Offline Steve F
Re: USD Fork swap.....what should i make this bushing out of????
« Reply #20 on: May 24, 2013, 23:39:52 »
A mate made a stainless steel sleeve for me, the lip stops it working its way up through the bearing, it also made it easier to press on.  The bearing was then pressed on to the sleeve.  I dont see any wear issues with this and it should last just fine, cost was very cheap as well.
Cheers
Steve
Offline Rich Ard
  • doin' the backstroke in an estrogen ocean
« Reply #21 on: May 24, 2013, 23:43:54 »
Very cool. It's a snug fit on the stem i presume?
unplug the connectors from the harness and multimeter the shit out of them
Bad Points, a comic :: CB450 Restomod (sold) :: Viragostrosity :: GL1000 daily rider :: Kaw 175
Offline Steve F
« Reply #22 on: May 24, 2013, 23:47:55 »
Yep used some pipe on the lip to press it on the stem and then the same process to press the bearing on the sleeve.  The lip also acts as a spacer so the bearing is raised to the right spot and the lower triple clears the frame.
Cheers
Steve
Offline Mydlyfkryzis
  • 当有疑问时踢你的敌人在生殖器上,你可以道歉后
    • CB360 Build
« Reply #23 on: May 25, 2013, 00:07:27 »
I like it, but being a belt and suspenders kind of guy, I would of put a drop of strong loctite on the inside of the sleeve, just for insurance.
« Last Edit: May 25, 2013, 20:04:21 by mydlyfkryzis »
There are 10 kinds of people, those who know binary and those who don't
Ignorance is bliss....and there are a lot of happy people out there!
AlphaDogChoppers: "A friend of mine once said, "There's no such thing as a stupid question, but there sure are a lot of inquisitive idiots."
"if you need a hammer to do something...  you are probably doing it wrong" - LazloH
DTT Blue CB360 Club - We discriminate!
Mydlyfkryzis = Mid Life Crisis
1991 Honda Nighthawk 750
1976 Honda CB360t
http://www.dotheton.com/forum/index.php?topic=41649.new#new
Offline Steve F
« Reply #24 on: May 25, 2013, 00:25:50 »
Funny you should say that, forgot to mention that :) Although I'm not sure how much stayed there.
Cheers
Steve
Sent from my GT-I9300 using Tapatalk 2
Offline o1marc
    • Creative Candy Powder Coating
« Reply #25 on: May 25, 2013, 00:31:05 »
Yeah I meant it...lol. That was the whole delema. No one makes a bearing with the right shaft size with te od I needed. I got it all figured out now.
When you say. "How it was put together" do you mean the forks or the bike?
I traded a guy on CL staright up for a xt parts motor I didn't need. That is why my cost is so low.
Read it again and tell me that's what you meant.
Offline MILLENNIUM FALCON
« Reply #26 on: May 25, 2013, 01:11:35 »
This is exactly what I did. I'm glad it worked out for you. I hope I have similar results.
Cheers
Steve
« Reply #27 on: May 25, 2013, 01:13:49 »
I meant to say..."they aren't perfect. 30mm I.D bearings as a close as I could get. I needed 28mm.
Offline Rich Ard
« Reply #29 on: May 25, 2013, 01:20:53 »
So when he does it, its cool? lol  ;)
Ha! I didn't realize that it wasn't a picture of your setup.
