Author Topic: Teledan's XT500 project  (Read 15879 times)
Offline teledan
« on: May 31, 2013, 13:13:40 »
Hi Everybody, I thought I would post a bit about my current bike and what I have done with it so far.  I have been into old Harley’s for a few years now and after getting married and having a couple kids I ended up selling my bikes.  We all know how these machines get into our blood so of course I started getting the itch again very soon.  I had been browsing the web for a cheap bike that I could molest and fell in love with the Yamaha SR500.  After looking around a bit for one of these bikes for sale I realized that they were just way too hard to come by in the states but I then discovered the XT500.  It is basically the same motor but dressed in a more off-road trim.  I ended up finding an 81 XT500 in Idaho for a few hundred that was running and seemed to be in decent shape.  Apparently it was an old Forest Service bike so it was a bit beat up and smoked a little but it was a good start.  Here’s how she looked when I brought her home:
 I cleaned the carb real good and put a new front tire on and rode it like that until the winter.  I wanted to do a sort of cafe/tracker type bike but I still wanted to ride it as much as possible and have a really tight budget so I started making small changes.  I threw on a new mikuni vm36, a battery eliminator, welded up a new exhaust from a Hoos Racing kit, new bars with a bar-end mirror, and a 12v lighting conversion.
 I was riding the crap out of it and I got sick of it smoking so I decided to do the top-end.  I figured while I was in there I would upgrade some stuff so I had Grim Cycle in Orem,UT bore the cylinder for a Wiseco 88.5mm 10:1 comp piston, do a valve job, and install new valve springs and seals.  I shot some paint on the jug and head and threw it all back together and she started right up on the first kick!  Its not burning or leaking a drop of oil so I am a happy camper.
New piston in:
Motor all buttoned up:
 I think I will ride it like this until next winter but I am planning on swapping the frontend for one from an XS750 so I can have a disc brake and then I’ll need to figure out a new seat/tail.  Anyway, here is how she sits today:
I am trying to head in a sort of Street Tracker/Road Racer direction with this bike but money is tight so it will be a very slow process.  I am having a blast on it though!
« Last Edit: May 31, 2013, 13:16:44 by teledan »
Offline DreadRock
  • Bang Cut Grind ..Dam Did I Need That Part ?
Re: Teledan's XT500 project
« Reply #1 on: May 31, 2013, 15:23:34 »
Very cool man I just picked up a TT500 and heading down same road with it ! If I may ask was the pipe hard to do and was a fair price ? I'm a lil ways off from starting on it as I have two other builds almost done and the TT is next ! Anyways nice work and look forward to your build !
Offline teledan
« Reply #2 on: May 31, 2013, 15:33:09 »
Thanks man!  The header was $65 and the megaphone was $47 from Hoos Racing, I also wanted to do an upsweep so I bought a mandrel bend from JC Whitney for like $16.  It was pretty easy to weld up, it was the first pipe I have ever done.  I did a slip fit joint between the header and the megaphone and used springs to hold it in place too.That way if I wanted to run a muffler instead of the megaphone it would be easy to swap on.  It is pretty dang loud so I may end up putting a muffler on, or I may just sell it and do a high pipe with a Cone Eng. muffler instead, I don't know.
Offline Bert Jan
  • Holy Modification Batman
    • Outsiders Netherlands
« Reply #3 on: Jun 03, 2013, 13:49:48 »
nice laro!
Offline teledan
« Reply #4 on: Jun 03, 2013, 14:05:55 »
nice laro!
Thanks!  Here is our "fleet"
We rebuilt the white D90 after it was wrapped around a tree.  New galvanized frame, Rovertym suspension.  Just got it registered!
Offline hillsy
« Reply #5 on: Jun 03, 2013, 20:30:57 »
I think I will ride it like this until next winter but I am planning on swapping the frontend for one from an XS750 so I can have a disc brake and then Iíll need to figure out a new seat/tail.
Just so you know, a KZ650 / 900 front end will slot straight into your XT triples. I mean STRAIGHT IN - the forks are the same diameter and offset - so no mucking around with bearing swaps or axle spacers, etc.
Offline teledan
« Reply #6 on: Jun 04, 2013, 11:51:24 »
Good to know!  Are there any specific years to look for?  From the measurements I have taken, the '77 XS750 forks should do the same and I should be able to use a spoked wheel from an XS650.
Offline hillsy
« Reply #7 on: Jun 04, 2013, 19:38:04 »
All the KZ9's will fit (73-76), and the first model or two of the 650 (the wire wheeled ones). Not sure about the later 650's (SR's and the like) or the KZ1000's. The 650 forks are a little shorter than the 900's so the 9's would be the pick of the two for an XT.
Offline teledan
« Reply #8 on: Jun 06, 2013, 12:13:43 »
Cool, thanks for the info!
Well, my rocker box is getting real noisy so it looks like I need to pull the motor and install some set screws to hold the rocker shafts in place.  Wish me luck!
Offline teledan
« Reply #9 on: Jul 18, 2013, 15:28:23 »
Did some surgery:
She's nice and quiet now.  I'm gonna try to make a seat now.
