Author Topic: 81 SR250 tracker build help  (Read 13171 times)
Offline zap2504
Re: 81 SR250 tracker build help
« Reply #50 on: Jun 25, 2016, 18:24:18 »
Any one have advice on weather to replace an old leaking from every gasket tank valve (petcock) with a cheap New Chinese whole assembly or buy an oem $50 gasket kit?
You may be able to replace the vacuum-controlled OEM unit with a Yamaha manual unit (many XTs and TTs used this) and many times this is doable regardless of displacement. You will need to either take your old one to a dealer to compare the mounting base, or measure and search, or maybe someone else has done this already. OEM quality is always preferable.
Offline JadusMotorcycleParts
    • Jadus Motorcycle Parts
« Reply #51 on: Jun 27, 2016, 18:55:22 »
Have bought one of these before and the quality was great.  Same hole centres, good price.  I just think it was missing the base o-ring.
Then you would just have to cap off your vacuum feed on the intake boot.
http://www.ebay.co.uk/itm/KAWASAKI-ENDURO-MOTOCROSS-FLANGE-PETROL-TAP-FLANGE-LEFT-OUTLET-34mm-CENTRES-/151013012531?pt=UK_Motorcycle_Parts&hash=item232913b433
