www.Moto-Madness.com
Author Topic: Lowering Kawasaki Z650 D4/LTD -81  (Read 1571 times)
Offline ABOM
« on: Jul 21, 2013, 12:59:43 »
Hi guys,
I'm about to start on my first project. A Z650 D4/LTD -81 that I am going to change mostly simple parts i.e. seat, stearing etc. What I'm though is interested of is if it's common to change something regarding the suspension (front or rear), and how that is done. Interested in all ideas.
KZ650
Offline o1marc
    • Creative Candy Powder Coating
Re: Lowering Kawasaki Z650 D4/LTD -81
« Reply #1 on: Jul 21, 2013, 14:59:20 »
Where are you from? Why do you want to change the suspension? Looks or improvement in handling?
Offline ABOM
« Reply #2 on: Jul 21, 2013, 15:32:48 »
From Sweden. Actually just the look. What I've seen is that there are many that are lowering their bikes, either front or rear, for the look. Believe that the front could be lowered for a nicer look, or if it's maybe easier to highten the rear...?
KZ650
Offline o1marc
« Reply #3 on: Jul 21, 2013, 17:13:29 »
If you are lowering the front you can either push the fork tubes through the top triple tree if there is room. You can get shorter fork springs. Lowering the bike will probably adversely effect the handling.
Offline ABOM
« Reply #4 on: Jul 21, 2013, 17:23:09 »
Thanks,
Gonna look into pushing the fork tubes. Will se if there is much difference in handling.
KZ650
Offline ako
« Reply #5 on: Jul 21, 2013, 17:27:54 »
Generally speaking, leaning the bike forward will make the bike more responsive in turns but more skittish at speed.
Leaning the bike bike will make it handle Ike a chopper, harder to turn but stable as speeds.
If you are riding around in snow and ice dodging moose on the freeway, you need your bike handling right.
Or are you just going to cruise the city?
Ride at the back and keep your spanners off our moles.
Offline ABOM
« Reply #6 on: Jul 21, 2013, 17:37:59 »
The bike is going to be used May-October and hopefully not during snowy days.. Hopefully it's gonna be a cruiser with the possibility of doing more than cruising some times. Should be a bike that can turn on tight roads, but also be able to go up to 100mph and maybe over..
KZ650
Offline o1marc
« Reply #7 on: Jul 21, 2013, 23:30:28 »
If you are going to be riding it aggressively I would leave it the way the manufacturer intended it to be. Changing it to look more aggressive or cool will negatively effect it's handling. Put better shocks and tires on it if you plan on riding it at 100mph
« Last Edit: Jul 22, 2013, 21:10:02 by o1marc »
Offline ABOM
« Reply #8 on: Jul 22, 2013, 12:04:29 »
If you are going to riding it aggressively I would leave it the way the manufacturer intended it to be. Changing it to look more aggressive or cool will negatively effect it's handling. Put better shocks and tires on it if you plan on riding it at 100mph
Ok. Good to know. Thanks!
KZ650
