Author Topic: Norton / Harley Ironhead Cafe Project.. Build thread  (Read 92195 times)
Offline The Limey
  • Evil English Villain
Re: Norton / Harley Ironhead Cafe Project.. Build thread
« Reply #380 on: Jun 18, 2018, 08:25:17 »
My chum had Yamaharley decals made up for his Harley/Yam bitsa.  No one knows what that means either, but if they can be bothered to ask he's happy to tell them.
Norvill, Triton, Tribsa, there is an ancient tradition of such names, and bikers understand the history and significance of such monikers.
Offline Bevelheadmhr
« Reply #381 on: Jun 18, 2018, 13:26:20 »
Indeed, Triton, Norvil etc are now recognised classics in their own right, but not sure you could say the same about Norley. I've seen alternatives mentioned such as Harton and Nordon, though I quite liked Narley. Given the frame is the classic featherbed Norton, I went for Norton on the tank in the end. It might cause a raised eyebrow with the rivet counters of the classic world, but they can be ignored lol.
Offline DesmoDog
« Reply #382 on: Jun 18, 2018, 19:56:33 »
I've wanted to build something like this for years. I'd call mine a Snortster.
Offline AgentX
« Reply #383 on: Jun 20, 2018, 23:58:06 »
Can't wait to see it mounted up.
"What's the use of having a motorcycle if you can't go tearing around staying out late?" Ralph asked reasonably.
« Reply #384 on: Jun 21, 2018, 16:42:37 »
Sadly an idiot damaged the paintwork while fitting the Monza fuel cap...  I was livid...as the idiot was me.   :(
Spoke to the painter and it can be repainted when he gets back from holiday in a couple of weeks
« Reply #385 on: Jul 01, 2018, 12:05:04 »
About half way through making the new foot levers/pegs. Next step is to machine the bronze bushes which they'll pivot on, and make sure the new parts will fit on the billet mounts already made for the bike. When all the machining is finished, I will of course spend an hour or two polishing them.
« Reply #386 on: Jul 13, 2018, 10:15:07 »
Test fit of the new levers, we used roller bearings rather than bronze bushes.. still needs polishing of course, though I may have the pegs ceramically anodised..
« Reply #387 on: Sep 21, 2018, 18:23:14 »
My alloy Mark 2 gear lever looked good, a pity it didn't work, as it didn't move the splined gear lever enough to actual change gear. So a MK3 version was made, which works but cant say I'm happy with its looks. But at least I've got the option to mount the link rod in a lower position, if it works ok, then I can shorten the lever. Another option is to shorten both the gear change lever and the splined lever too... have to cut it in half, take an inch out of it, reweld it back together and finally have it re chromed. Cant be bothered with all that right now, but maybe something for later..
« Reply #388 on: Feb 14, 2019, 07:58:08 »
I don't have as much time to spend on the bikes these days, but I work on them when I can. I've finally completed a full rewire of the Norley using a M-Unit from Moto Gadget, same one as I had fitted to my Merch 131 last year. They make the wiring so much simpler and neater, and also include a built in alarm, so I've just ordered another for the Guzzi. I've not touched the Guzzi for more than a year, but with the Norley almost done (famous last words), the Guzzi has swapped places with the Norley in the conservatory where I can work on it.
Still waiting for the paintwork to be done, I shouldn't have said 'no rush' to the painter.. last August, just called him and been promised it'll be ready the end of next week, but I'm not holding my breath.
Also been doing a few small jobs on the bike, such as adding a stainless screen mesh to the homemade velocity stack and machining a grove in the lock stops to fit an 'O' ring to each to act as a bumper so they wont damage the powder coating on the frame at full lock. Also made a pair of fender mounts which clamp around the fork lowers, means I can use the fender I wanted to use all along. Still lots to do, but (fingers crossed) it'll be running and road legal in time for spring.
Offline grandpaul
  • Author, "Old Bikes"
    • Born Again Bikes
« Reply #389 on: Feb 14, 2019, 22:39:40 »
Wouldn't your gearshift linkage be more effective (leverage ratio) by shortening the tranny end lever a bit?
It ain't braggin' if ya done it.
