Author Topic: Suzuki GR650 Scrambler/Tracker - The Strangler!  (Read 26644 times)
Offline Joe Suzuki
    • Everything is Better With Knobbies!
Re: Suzuki GR650 Scrambler/Tracker - The Strangler!
« Reply #50 on: Feb 07, 2014, 00:27:49 »
This was a test.  Its a GT380 tank.  I was amazed how well it fit.
Offline Joe Suzuki
« Reply #51 on: Sep 04, 2014, 16:47:33 »
OK, WAAAAAY overdue for an update.  Lots of excuses you don't care about.  Big Rich shamed me into it!
Been working behind the scenes on many aspects of the bike and ordering a BUNCH of parts.  I don't have the greatest pictures of all the ongoing work, but I'll put up what I have done recently. So here goes...
Wheels got dismembered, powder coated a textured black, new All Balls bearings installed, then sent to Buchanan's for custom stainless spokes.  I'll get some pictures up soon.  But here are the tires that will be going on:
Built a headlight mounting bracket and test fit new headlight.  Got new x-ring chain and sprockets, -1 in back, +1 in front.  Got All Balls steering bearings.  Got parts for Rect/Reg swap, Shindengen FH012 from an R1 or something.  Got new Electrosport Stator.  Got new glasspack mufflers on order.
But mostly been working on the seat and rear subframe.  I had an old 1983 PGO Scootor (Thai clone of a Honda) that had a seat that was almost right for what i was looking for.  I cut the pan down, cut the front short, and reshaped the foam a little, then sent it off to Lauren at New Church to lay some kick-ass textured vinyl onto.  I'll save that for a reveal a little later.  Then I got to working on the subframe.  I bent up new bars to match the seat and added a rear hoop.  Don't pay too much attention to the extra long tubes, they will get cut short close to the hoop.  Next are the down tubes, hopefully by the end of the weekend.
Frame Mods
Subframe and Tank
Subframe, Tank & Seat
Ducati Monster Shock Swap soon...
As for the EFI update, I've decided (i.e. ran out of money) to make that a Phase 2 of the project once the bike is complete.  That will be a good winter project.  So for now, it'll get K&N oval tapered pods and a re-jet.  When I redo the electrical, I'll try to keep the EFI in mind and plan accordingly.  More updates to come.
Offline Big Rich
  • Heaven is so far away.
« Reply #52 on: Sep 04, 2014, 21:16:48 »
Looking pretty darn good, Joe!
What are you going with as far as carbs go? I would assume stock since you'll be swapping to EFI later on.....
And can you do me a favor? If you pull the spring off the Ducati shock, can you check the wheel travel? I looked recently and saw that a Monster has something like 2" more suspension travel than the GR, and I'm hoping it's not because of the shock itself.....
Offline Joe Suzuki
« Reply #53 on: Sep 05, 2014, 00:40:55 »
Thanks Big Rich!  Just the stock carbs with a 6 Sigma rejet.  You had stock carbs before going to the VM's.  Did you rejet?  Why the VM's?  I'll check the travel once I get one of the missing hat-bushings for the top of the shock eye.  Ebay seller neglected to mention it missing, and I'm having a hell of a time getting one.  I suspect the GR travel is limited by its geometry.  But if the shock itself has more travel before it bottoms, then the swingarm should travel further too.  We'll see...
Offline Big Rich
« Reply #54 on: Sep 05, 2014, 01:23:24 »
I actually found a really good deal on a used set of VM carbs and liked how they ran. After I had them for a little while, I bought a new set of carbs to replace the used ones. When I was running stock carbs I was in the process of jetting them for pod filters when the opportunity to upgrade came along......
I appreciate you checking if you're able to. If you can't for whatever reason, I'll do it myself just to be certain.
Offline Joe Suzuki
« Reply #55 on: Sep 09, 2014, 12:12:39 »
So after disassembling both the stock GR shock and the Ducati shock, I have some minor issues to deal with.  The Ducati shock has about 1/2" less shock travel than the Suzuki one.  Not good.  Especially for a tracker/scrambler type built, I do not want to limit my travel at all.  I haven't yet measured to see what this means for overall travel on the bike, but if anything, I need more, not less!  So put the original back in?  Well the foam bump-stop was disintegrated upon dis-assembly.  So I could rig up some sort of slip over the shaft bump stop, run without, or shitcan the whole suspension setup and design some new geometry/mounts, etc.  Frustrating  >:(
Offline adtree
« Reply #56 on: Sep 14, 2015, 23:24:45 »
sorry to drag up an old thread... but that mockup looks tops... building a gr650 myself... and have been for the past 10 years on and off.
Hows this one tracking?
I ended up with a monster shock after combing a wreckers for hours aswell. Its sat on the shelf for years without attention - you get yours to work?
Offline Joe Suzuki
« Reply #57 on: Sep 21, 2015, 09:24:49 »
Been on the back burner for a bit since I moved from the Northwest to San Antonio, TX into a garage with no welder or compressor outlet!  I'm working to rectify that situation shortly.  My pics are a bit behind my actual progress as well.  Frame is nearly complete, just need some seat mounting points and some fender mount tabs, but again, welder...  Turns out my monster shock was missing one of the hat bushings at the top eye, which was not communicated to me by the ebay seller.  That would be fine if I had a Monster, just swap it out, but I don't, so I'll have to machine a replacement.  Still not sure if its going to give me the height I want though, so the jury is still out.
Offline redwillissuperman
  • Keep it simple- engine, wheels, bars
« Reply #58 on: Oct 10, 2015, 21:31:51 »
Do you have an outlet for a dryer? Weld in the laundry room or use the dryer vent outlet to snake the cord into the house and plug it in. I wonder how I know....
Offline Joe Suzuki
« Reply #59 on: Oct 12, 2015, 11:06:54 »
Nice! I'm sure you followed the proper Universal Building Code guidelines...  ;)
