Author Topic: '83 CM450e brat tracker  (Read 17870 times)
Offline sbruton
  • Where the fvck is that money you owe me?!?
Re: '83 CM450e brat tracker
« Reply #40 on: Jan 14, 2014, 20:05:03 »
Yup.  If your bike has already been plated in Alberta you won't have an issue BUT if you need to get an inspection to get your registration they'll hold you to all the regulations.  That is; UNLESS you know somebody.
Offline D4N63R
« Reply #41 on: Jan 14, 2014, 21:07:48 »
The bike was actually just OOPI'd buy the previous owner last summer, so its good to go :)
went and got my parcel, dang tires are here already! guess im doing some spooning this weekend.... I hate changing tires ha
and this was in the mailbox :)
Offline Little Heat
« Reply #42 on: Jan 15, 2014, 23:44:34 »
Hey this is an awesome build, seems similar to what I'm doing, I'm working on an 82 nighthawk 450 going the tracker look with it too,  excited to see how this goes
Offline D4N63R
« Reply #43 on: Jan 15, 2014, 23:51:05 »
Well assuming I get the tires on this weekend. It's pretty much 'put it back together time' curious to see how it looks myself.
I also have another parcel slip. It's either mirrors or helmet.
Offline D4N63R
« Reply #44 on: Jan 17, 2014, 11:13:39 »
Just ordered a jet kit, new gas cap seal, petcock and throttle tube. That should handle the little bits. everything else I should be able to get locally easy enough.
Offline sbruton
« Reply #45 on: Jan 17, 2014, 17:55:23 »
Time to start buildin' this thing already!
chop. chop.
 :D
Offline D4N63R
« Reply #46 on: Jan 17, 2014, 18:02:33 »
gah I know... Only one shit job left and thats changing the tires.... then it all starts going back together hahaha
Offline D4N63R
« Reply #47 on: Jan 18, 2014, 18:31:10 »
Changed the tires today (video to come) got a bunch more painting done and swapped my new pegs on. I'll get the wheels painted throughout the week then re assemble the bike next weekend if all goes well.
Old tire sidewall hahaha.
Offline D4N63R
« Reply #48 on: Jan 19, 2014, 20:46:34 »
super long tire change video is now done! hahaha
Offline D4N63R
« Reply #49 on: Jan 20, 2014, 20:41:37 »
The Internet lies!!!!!!
Everything I read said a cb450 wheel should be a bolt in affair in the rear. Well that's not true. The cb uses a larger diameter axle, and a narrower swing arm. The overall axle length is the same. I can make the swing arm holes bigger easy enough but I'm going to need some longer spacers. Uhg. What a pain :(
