Author Topic: Cafe XV920R Mega-Build  (Read 15083 times)
Offline MORK
  • Back at er
Re: Cafe XV920R Mega-Build
« Reply #30 on: Mar 18, 2017, 12:08:02 »
Absolutely wonderful work. Good luck choosing a tank - with that narrow backbone, the possibilities are endless...
What kind of clearance do you have under the oil pan with that setup?
Offline JAGspeed
« Reply #31 on: Mar 18, 2017, 21:52:57 »
I have about 150mm of clearance should be OK. I also incorporated the ride height adjustment in my suspension design so I have the option of raising the rear a bit if needed.
XS650 Tracker build Mod Style: http://www.dotheton.com/forum/index.php?topic=48134.0
Cafe XV920R Mega-Build: http://www.dotheton.com/forum/index.php?topic=55864.0
CB750 Resto-Mod build:http://www.dotheton.com/forum/index.php?topic=58358.0
Offline JAGspeed
« Reply #32 on: Apr 08, 2017, 00:48:08 »
Picked up a tank on Ebay from a BMW 9T. Really liked the shape of it ever since it came out. It had some minor damage but nothing to serious. I did have to do some surgery to the underside to make it fit and I will have to cap off the hole for the fuel injection and add a petcock.  It is an aluminum tank so there will be some TIG welding involved to make it work. The nice thing is there is plenty of room under the tank for the battery and all the electronics.   After I get in mounted I am going to work on my tail section.
Offline bikeWillem
  • Suzuki FTW
« Reply #33 on: Apr 08, 2017, 11:05:09 »
Awesome build! The tank looks really good and I think it suits the bike really nicely.  :)
Offline MORK
  • Back at er
« Reply #34 on: Apr 08, 2017, 11:17:56 »
Woah. Wasn't expecting that at all. I'm picturing it with some motocross bars and the 9T scrambler subframe now...
Offline MORK
  • Back at er
« Reply #35 on: Apr 08, 2017, 11:22:11 »
For a while on mine I was thinking of using an XSR900 seat, but there wasn't a way to cohesively line up the tank and the subframe it would require. It looks like it could line up with that tank really well. (They are also cheap brand new from places like motosport on the microfiche)
Offline SF
« Reply #36 on: Apr 08, 2017, 13:56:32 »
Really impressed with the fab and detail. What welder are you using? Tank looks at home.
72 R5
75 CB550 PROJECT
72/73 S2 RACE BIKE
72 CB350 MOM'S BIKE
Offline JAGspeed
« Reply #37 on: Apr 10, 2017, 13:32:37 »
I'm using a Lincoln MIG welder so far because I am comfortable with it. I have access to a TIG but need some time on it to be able to run clean welds. I may try and TIG the tank myself, but I will most likely have a friend of mine that is a professional welder help me out.
Offline MORK
  • Back at er
« Reply #38 on: Apr 15, 2017, 16:30:34 »
I'm envious of your frame height it would seem then - everything I find lists the 08 600rr forks at 720mm fully extended and my 05 R6 forks are measuring 736 at ride height and I only have ~3" (76mm) of clearance right now.
Good work - I'm off to contemplate dropped triples, etc.
Offline JAGspeed
« Reply #39 on: Apr 16, 2017, 02:16:55 »
The CBR forks are fairly short but are great units. I knew I was going to make my own frame so it was not an issue. I did move the head stock of my frame down several inches and back some to achieve the ground clearance I desired. The closer distance will also reduce flex in my frame and improve handling.
