Author Topic: Cafe XV920R Mega-Build  (Read 15108 times)
Offline Stribolt
Re: Cafe XV920R Mega-Build
« Reply #40 on: Apr 16, 2017, 05:17:46 »
Taking my hat off 🤠 nice work
Offline JAGspeed
« Reply #41 on: Apr 21, 2017, 12:04:22 »
Working on the tail section. I was able to make a subframe tail section out of tubing. It also ties the rear of the frame to the billet parts for added strength. I am going to add some pieces to the back of the tail section to fill it in. The muffler will run under the tail and exit at both sides of the rear part of it. This part is removable so I could make other tail sections later on to give the bike a whole different look.
XS650 Tracker build Mod Style: http://www.dotheton.com/forum/index.php?topic=48134.0
Cafe XV920R Mega-Build: http://www.dotheton.com/forum/index.php?topic=55864.0
CB750 Resto-Mod build:http://www.dotheton.com/forum/index.php?topic=58358.0
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
« Reply #42 on: Apr 21, 2017, 12:22:15 »
That's pretty solid man. I dig it, did you mig weld that all up? What size tubing did you use?
Live to Die, Die to Live
Offline JustinLonghorn
« Reply #43 on: Apr 21, 2017, 12:34:18 »
You should leave the BMW emblems on it just to fuck with people.
Into The Sunset, CB750 build
TT500 the Animal
Offline canyoncarver
  • 'hacking is learning'
« Reply #44 on: Apr 21, 2017, 13:46:12 »
I love that tail you are building..    How did you get those bends?  Just heat or do you have a bender?
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline SF
« Reply #45 on: Apr 22, 2017, 00:23:52 »
F.... Ya!
72 R5
75 CB550 PROJECT
72/73 S2 RACE BIKE
72 CB350 MOM'S BIKE
Offline JAGspeed
« Reply #46 on: Apr 23, 2017, 00:55:08 »
I did mig weld the subframe still have to finish up a couple of welds though. I used 3/4" tubing.
Offline JAGspeed
« Reply #47 on: Apr 23, 2017, 01:03:06 »
I have a tube bender. I did have to weld several bends together in places because some of the bends were to close together and would not fit in the bender. I also used a press in a couple of spots to tweak some of the pieces to try and keep both sides symmetrical.
Offline Karlloss
« Reply #48 on: May 02, 2017, 12:56:02 »
Awesome subframe assembly!
Offline JAGspeed
« Reply #49 on: May 06, 2017, 23:00:04 »
Made a seat pan out of fiberglass. I taped everything off first and laid down several layers of mat. After it hardened I shaped it to fit. I'm sure I'll be itching for a bit, but happy with how it came out. Just need to add a couple of mounts then I'll glue in and shape the seat foam.
