Author Topic: Xr250 street tracker  (Read 27415 times)
Offline Kg_Customs
    • Cm 400 scrambler
Re: Xr250 street tracker
« Reply #40 on: Feb 20, 2014, 14:07:04 »
Thanks guys I'm pretty happy with how it's turning out!
The rear tire is tubeless and the front has a tube. This is because of shinko's tire sizes, the 120-17 is a tube type tire and the 130-17 isn't. I didn't want to risk running a tube tire without one even though my rims are a tubeless type(a $20 tube is cheap insurance). I now know I would be able to squeeze a 130 up front and would recommend anyone else to do so if they had the same setup. Which is: gs500 mags front+rear, gsxr 600/750 forks, custom spacers in the back(easy to make) and a custom front axle that I made. I hope the info helps!
We restore, paint, and customize vintage motorcycles. Specialized in Japanese and European bikes built to suit your needs.
K_Grendell@yahoo.com
I.G.: Kg_Customs
F.B.: Kg Customs
Latest build:
http://www.dotheton.com/forum/index.php?topic=56433.0
Offline 1sttimer
« Reply #41 on: Feb 20, 2014, 20:39:28 »
Just curious, are you trying to get a title for this thing?  I'm from NC where it's nearly impossible to do so on a machine like this.
Or are you from one of those awesome states where it's a non issue?
1973 CB175
http://www.dotheton.com/forum/index.php?topic=53893.new#new
"There is never enough time to do it right the first time, but there is always enough time to do it over."
Offline Kg_Customs
    • Cm 400 scrambler
« Reply #42 on: Feb 20, 2014, 22:50:04 »
It came with a title. The xr250 L models where street legal and titled for us roads with l the dot crap from the factory. That said my state is terrible to get titles in but I do have a legal way around it if need be, just a few bucks and some time for me.
I.G.: Kg_Customs
F.B.: Kg Customs
Latest build:
Offline Serial__Thrilla
« Reply #43 on: Feb 21, 2014, 03:34:18 »
KG, you're the man! This thing is cool as hell!
Offline Kg_Customs
    • Cm 400 scrambler
« Reply #44 on: Mar 25, 2014, 21:33:30 »
Thanks for the love serial!
Quick update; I've only been able to sneak a few hours in here and there in between customer bikes but here's today's.
Finally got new swingarm bearings in, rear swinger and custom dog bone came back from powder, made some rear axle spacers for the brake upgrade, finished the headlight battery box and got it in primer,
Shaved the tabs for gauge mounts of my upper triple, made a slick new mount for the acewell speedo, primed the modded upper triple finally, and tested my led headlight w/relay out its bright as f&$k!
Tomorrow I might be able to sneak in another few hours button up the paint and front end and get the wiring started.
I.G.: Kg_Customs
F.B.: Kg Customs
Latest build:
Offline DesmoBro
  • Busted Nut
« Reply #45 on: Mar 25, 2014, 21:45:23 »
Nice job ....pipe looks funny just hovering there
"I desire the things that will destroy me in the end"
Offline Joe Suzuki
    • Everything is Better With Knobbies!
« Reply #46 on: Mar 26, 2014, 11:41:04 »
Looking sooooo awesome! I love that tank, and the stance, and the seat, and the tires...  I could go on.  Did you have to do anything funny to get the sprockets to line up?  I've got a similar rear wheel, and its way offset.  What bike is your rear wheel off of?
Offline Kg_Customs
    • Cm 400 scrambler
« Reply #47 on: Mar 26, 2014, 13:35:35 »
Thanks Joe.
The wheels are off a suzuki gs500. It only took me a little bit of work to make a custom spacer so I could line it all up. It does have upgraded sprockets to an oring type, but they line up to be pretty close before hand. I've got a full fab shop so it's never too much trouble to make things work just time. If your local to me I can lend a hand.
I.G.: Kg_Customs
F.B.: Kg Customs
Latest build:
Offline Joe Suzuki
« Reply #48 on: Mar 26, 2014, 14:12:40 »
Not so much local.  I'm about 3000 miles away, but thanks for the offer.  My rear rim is from a 94-99 Katana GSX750, which should be very similar to a GS500 rim, but there may be width differences.  I have two problems, sprocket alignment, and the whole wheel/brake assembly is about 1/4" to long to fit in my swingarm.  What's your swingarm inside measurement?  I'll have to measure mine and see how close it is to yours.  Maybe a GS500 is narrower and could work with my setup.  Thanks!
Offline belmont
« Reply #49 on: Mar 26, 2014, 14:40:41 »
That thing looks like it would be a blast! Really impressed with the work so far!
