Author Topic: drop seat kz  (Read 11501 times)
Offline Schmeck750
  • If you can't buy it, build it.
Re: drop seat kz
« Reply #30 on: Mar 02, 2014, 13:51:16 »
Pic
Offline Schmeck750
Re: drop seat kz
« Reply #31 on: Mar 02, 2014, 13:56:58 »
Not bad for a fluxcore welder huh. Still doesn't look as good as tig but it should hold my heavy a** lol.
Offline crackerman
    • 79' KZ750 builds
Re: drop seat kz
« Reply #32 on: Mar 02, 2014, 14:27:12 »
Going to run a single carb on that engine? Let me know how that works for you.
Offline Schmeck750
Re: drop seat kz
« Reply #33 on: Mar 02, 2014, 16:26:48 »
It ran okay at the time. Had I shortened the intake it would have ran perfect but as of right now I will probably put the originals back on when all is said and done. Got enough money in the project to be fooling with the intake again lol
Offline VonYinzer
Re: drop seat kz
« Reply #34 on: Mar 03, 2014, 08:10:13 »
Post a pic of the frame from the side.
Offline Schmeck750
Re: drop seat kz
« Reply #35 on: Mar 03, 2014, 16:15:26 »
Which side? I'm going to get the other top bar welded on in just a few. Can't do the bottoms till a) motor is pulled and b) the local machine shop bends my tubes so that I don't have to run straight tubes.
Offline Schmeck750
Re: drop seat kz
« Reply #36 on: Mar 03, 2014, 16:24:46 »
Side
Offline canyoncarver
  • 'hacking is learning'
Re: drop seat kz
« Reply #37 on: Mar 06, 2014, 15:00:17 »
So....  I like the springer front end and I like the idea of a hardtail on this bike.  I'm just not digging the design on the rear you have going there. I do want to see how it gets finished up though.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline Schmeck750
Re: drop seat kz
« Reply #38 on: Mar 06, 2014, 15:33:33 »
Yeah the design is alittle far from what I wanted. I was worried about the structural integrity of the top bar if it was damn near flat at the connection . If I was using a tig machine Id be doing all sorts of designs buuuuuuuut I don't. I'll post a picture in a bit when I get the bottoms welded on . Got them at least fitted with the 3/4" rods and I pulled the motor so that I could move the frame around better .
Offline xb33bsa
Re: drop seat kz
« Reply #39 on: Mar 06, 2014, 15:50:45 »
that top tube being bent is the issue, it will be constantly flexing
it should be straight or another added at the bend to tie things together
