Author Topic: 1973 XL175 Vitamin C Hell Ride  (Read 88715 times)
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
Re: 1973 XL175 Vitamin C Hell Ride
« Reply #450 on: Feb 10, 2016, 14:17:44 »
You don't need a CB-350 stator to run 12v, just swap the regulator.  It's the regulator that determines the voltage, not the stator/magnet.  More windings/flux equates to more power out of the alternator which varies as a function of rpm.  The regulator shorts it to ground to control the voltage.
Cool, can this work for a CB100 too, just installing a regulator?
2015 Toyota Taco DD now
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM runs, but no power
1984 Dodge D50 Beater was DD since 1997
Offline irk miller
« Reply #451 on: Feb 10, 2016, 14:21:56 »
I was taught this a while ago, but then made aware of the stator swap so I tried it out.  Power seemed to ground to the casing post swap, so I've gone back to the stock stator and I'm now using a 12v regulator.
Offline squared
  • squared
« Reply #452 on: Feb 10, 2016, 14:27:03 »
Not sure, I think the 185/200 has the same case/frame mounts (as well as the 100/125).  I doubt the 250 will fit, I bought a crankshaft for one thinking I could graft it into the XL I had a few years ago and it's a lot bigger.  I was also looking at the Chinese clone engines at that time as well, I think it fits.
1979 CM400T
1977 DT400
1975 CB360T
1972 SL175
1970 CL100
1969 CB350
parts
