Author Topic: Xs750 not starting after changing handle bars  (Read 6036 times)
Offline jxcktheripper
Re: Xs750 not starting after changing handle bars
« Reply #10 on: Mar 28, 2014, 13:43:48 »
No prob, I made all those mistakes the first time I put lower bars on LOL
haha yea I tried to save money and do it myself -_- ill post some pics so you can see the cables too
« Reply #11 on: Mar 28, 2014, 13:56:40 »
@maritime
Online Maritime
« Reply #12 on: Mar 28, 2014, 14:10:29 »
Yep your throttle cable is bent way too much that will make the reving issue, also your starter probably doesn't work cause the bars are painted and Yamaha grounds controls on the bars, sand paint off under the controls and that should fix it.  your cable needs to gently arc, tight curves are a no no.
Online Maritime
« Reply #13 on: Mar 28, 2014, 14:14:15 »
You will have to disconect the throttle and likely clutch cable and find a new route for them. the 2 red circles are real bad bends for the throttle.  Also the loop on your clutch cable is too tight as well
« Last Edit: Mar 28, 2014, 14:16:07 by Maritime »
« Reply #14 on: Mar 28, 2014, 14:14:28 »
ah! I knew it! Lol my gf was saying that last night too but I being stubborn and a man and trying to force it -_- ahaha thanks man! I'm just gonna switch them back until I can actually get it done properly. Do you know how much that might cost at a shop?
« Reply #15 on: Mar 28, 2014, 14:17:52 »
Damn! Lol I had that gut feeling saying it was wrong last night but I ignored it cuz I wanted to look cool ahaha
Online Maritime
« Reply #16 on: Mar 28, 2014, 14:25:17 »
not really, I do all my own stuff, make mistakes, learn, fix, move on LOL. I would look into if there were other models of the bike that came with lower bars from the factory and get the cables for that bike, or Motion Pro can make up cables.  Really not hard to re-route the current, just make gentle arcs, not tight turns.  I used the full length cables on my GL but put much lower bars what I did was make the cables go out away from the bars then curved them back towards the frame and crossed them over to the opposite side they were originally on and that made the difference. If I get the chance I will take a pic to show you what I mean.
Offline plagrone
« Reply #17 on: Mar 28, 2014, 14:31:53 »
Don't do thaaaaaaaat, it's easy. You've already done most of the hard work. All you have to do is disconnect some cables and reroute them, slide the right controls off a bit and sand where they contact the bars.
Besides, shops are too expensive
« Reply #18 on: Mar 28, 2014, 14:33:11 »
Hahaha that's a way to do it! I just wish I had more tools and a shop to learn in lol and alright I'll try that. All of this stuff is like another language right now I'm gonna try to get a friend of mine to help as well! Thanks again for the help man I really appreciate it. I'll keep you updated about the progress too!
Online Maritime
« Reply #19 on: Mar 28, 2014, 14:33:54 »
found a pic, not sure you can see it but the cables are the ones from the apehanges the GL comes standard with and  I put the Euro superbike bars on.,
