Author Topic: Introducing the Sparck Moto FB-11  (Read 34007 times)
Offline Habanero52
  • The Race......is only with yourself!
Re: Introducing the Sparck Moto FB-11
« Reply #100 on: May 27, 2016, 15:21:01 »
Thanks.
Glad that you are back.
Habanero52
Speed cost....How fast do you want to spend?
Follow the dream.
Why does life get in the way?
Offline eyhonda
« Reply #101 on: May 27, 2016, 15:34:17 »
You're welcome and thanks.   I just acquired one of my favorite vintage bikes - a cb175.   I'll use it as a test development bed for other things electronic.   So, yeah, I hope to get active here again.   This fuseblock project is pretty exciting stuff.
01 VFR800i, my daily ride.
90 RC31 Hawk GT 663, part Honda part Ducati .
09 Aprilia scooter, city scoot.
Offline Habanero52
« Reply #102 on: May 27, 2016, 15:38:33 »
That is a cool bike. I had one when I was in high school.
The fuseblock is awesome!
My son and I have a few unmolested CB160s.
Habanero52
Follow the dream.
Offline datadavid
« Reply #103 on: May 30, 2016, 11:46:44 »
 This is a cool project! Can you explain how relays are superior to microswitches so the village idiot here can understand?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #104 on: May 31, 2016, 19:27:46 »
Relays are basically high current switches. They provide a direct shot from the power source to the powered component (instead of having to pass through long sections of wire and multiple switches, as is the case in most setups).  They also allow the use of microswitches to run things like the headlight or coils, which usually isn't possible with the switches, directly.
Audaces fortuna iuvat.
1977 Honda CJ360 - Caf SOS - Stage One, Caf SOS - Stage Two
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline nightpoison
« Reply #105 on: Aug 30, 2016, 08:05:51 »
Question, when designing this did u take in to consideration a stock bike or one that's been modded? Can this be mounted in the stock location where the fuses r located now or will other mods need to be done to accommodate it
Offline Maritime
« Reply #106 on: Aug 30, 2016, 08:40:19 »
Nightpoison, it would totally depend on the bike. I used one of these and completely rewired my GL1000, used probably half the wire vs oem and was able to shorten a lot of circuits up etc. I found it really simple to create the circuits I needed off the FB-11 versus doing it with just a fuse block. Basically you power the board and ground it, then you can run the hot or + to the component then ground from the component to a ground spot close to it. I used about 4 frame grounds which cleaned up the wiring and made for a better ground in most cases.  The board has an LED indicator for each fuse so if one goes you see it immediately. It would have mounted in my factory fuse location but I chose to move it for easier access and to run less wires.  for a good example of what you can reduce, if you have ever seen inside an old bikes headlight bucket there is like 10 connectors and its stuffed with wires all going in and out for usually all the lights, and controls etc. I have the headlight plug, everything else is rin from the FB-11 to the control or light and then ground. way cleaner.
Cheers
Maritime
Offline nightpoison
« Reply #107 on: Aug 30, 2016, 09:01:31 »
That makes complete sense. I guess I didn't really think about the question. I have a 74 CB750 and it would be different for every bike. Thanks for your insight.
Cheers
Maritime
Offline eyhonda
« Reply #108 on: Aug 30, 2016, 10:10:18 »
Cheers
Maritime
I'm a bit late to check in here but it was cool reading how you installed the FB-11.   Neat to see something I was part of being used!  I'll be wiring one of my prototypes on my cb175 shortly.   I'm still waiting for Vintage Connections to fix their website so I can order a new connector kit.
Eric
Offline Maritime
« Reply #109 on: Aug 30, 2016, 10:24:11 »
I liked it and I will have to go back and re-do my connections, not on the board, those are good but I used the store bought bullets and even though I used shrink tube etc, I should have spent the $$ on the good ones from vintage connections. So over the winter if I have the spare funds I will re-do my bullets.
