Author Topic: SR250 Cafe build  (Read 23834 times)
Offline cosworth
SR250 Cafe build
« on: Mar 31, 2014, 23:34:23 »
Ok, I skipped the usual introduction post and I posted a couple images etc. and I thought I should start a build thread since I'd like to pass on anything I find out for the next guy or someone reads my build thread and fills me in on something that helps me out.
First off I want to give a shout out to barkingmadspeedshop. He's looked in his shop for some parts for me  given me some great advice and even put up with me being a no show when he invited me over to see his home shop and builds. Stand up guy.
So, the bike. Saw an ad online and drove out into the bush (Lake Cowichan) to grab it. Traded my old gas powered pressure washer that I paid $100 for and I got two scooters with no plastics in the deal. Sold the scooters for $100 so I can justify saying I got his for free since I paid that for the pressure washer.
So it came with no title and a pair or li-ion batteries. The chrome was in good shape and it has new Cheng Shin tires on it. Fork seals are great, chain is dead, etc. It runs, but once I ripped the airbox out it runs like crap. I hope to have some secondary main 130 and primary main 155 jets to start as a base once it's sorta done.
Goal, dummy build it, sort out the bugs, find my mistakes, ride it for the summer then pull it apart in the winter and paint the frame and motor. A two stage build process. That way, it's not a box of parts and a frame and I don't get married to a couple of dead end ideas.
If and when I finish the build I'll post after pics in this first post and add some page numbers to the milestones. Started with this:
Decided on some chinese clip ons and rear Ohlins copies, $150 total.
So the seat and tank got lined up and I was coaxed into ditching the stock tank. Thankfully. So a mototlanna seat was imported, $200 and a $5 ebay led taillight. The light was too high, the speedo I got off ebay for $40 was too high as well. I fabbed a light bracket but decided to ditch it yesterday. I'll tighten the clocks and lights up a bit more later on. I have an LED taillight and will go with an LED headlight too. Take it easy on the vintage charging system.
 A GT380 tank was had for $40. $5 in sheet metal and some grinding along with say $5 in wire and ArCo2 and the knee indents are half done. I literally sat on the bike and traced my knee along the tank with a Sharpie for the shape.
Mig welding on the lowest setting and cranking up the gas to 20 netted some non pinhole penetration. My welding skills are ok, but I really see that I'd prefer a tig in the shop. Oxy/acetylene just seems so archaic now. I've lowered the rear of the seat for a flat line stance. Don't worry. I've hacked off about 30 pounds of iron and plastic off the bike so far.
Ok, today I did some shaping and hammering. I want to share a little secret. I have a 2 1/2 inch hitch ball I mount in my vise to use for tight radius shaping. It works great with just a pall pein hammer. I made two passes with the mig just to make sure and quenched the sheet metal with a wet rag as I went to reduce warpage. Anyone that says a real welder doesn't use a grinder doesn't make pretty things that needs paint. I'll tidy this up a bit more before I get the bondo out to fill the craters and hammer marks etc.
So the seat was two inches narrower than the tank. The stock tank holds 10 litres, the GT380 tank holds 15 litres. Although now, I would assume the tank holds 13.5 litres with an inch taken out of the ass end.
So there we have it, my first bike build. Please, tell me what I should be reconsidering or what have you. I'm really open to suggestions. I want to build what I WANT yes, but I want a fun commuter that turns heads. No trailer queen.
« Last Edit: Apr 01, 2014, 00:53:50 by cosworth »
1981 SR250 café hot rod (sold)
1976 XS360 collector plates
1980 XS400 (on the bench)
1981 XS400 (in pieces)
2017 Husqvarna 701 enduro
Livin' the dream in western Canuckistan
Offline madmatt1
Re: SR250 Cafe build
« Reply #1 on: Apr 01, 2014, 02:12:52 »
I really like your idea of using a trailer hitch ball for shaping metal, quite creative.
CL350 build thread:
http://www.dotheton.com/forum/index.php?topic=58435.0
1977 Kawasaki KZ1000
2003 Suzuki SV1000N
1975 Kawasaki KZ400
1977 Honda CB750K basket case
Offline cosworth
« Reply #2 on: Apr 01, 2014, 04:15:41 »
Thanks Matt. I can't believe how much brain power has been dedicated staring at the ceiling at night or out the window trying to picture how this tank mod would go down. I'm glad I did it today. I should have the other side done tomorrow then I can shape a bit more with some heat and get a  bit more curve in the tank.
I'll see what my DIY electroplating experiment turns up and I might plate the inside of the tank just as a nice touch for $10 in vinegar.
Offline firebane
  • braaaaaaaaaaap
« Reply #3 on: Apr 01, 2014, 04:28:15 »
You got a link for that speedo? I like the looks of it.
Offline cosworth
« Reply #4 on: Apr 01, 2014, 14:34:51 »
Stupid ebay doesn't keep bought items long enough. I looked pretty hard for this exact one bit there don't seem to be any for sale right now. The selling point for me was that it plugged right into my harness. Everything lit up correctly. And the speedo ratio was right too.
I'll keep looking though my feedback scores for the seller when I get a chance.
Offline DesmoBro
  • Busted Nut
« Reply #5 on: Apr 02, 2014, 01:33:47 »
Nice...
"I desire the things that will destroy me in the end"
Offline firebane
  • braaaaaaaaaaap
« Reply #6 on: Apr 02, 2014, 01:35:33 »
Boo :(
Offline cosworth
« Reply #7 on: Apr 08, 2014, 20:49:28 »
Ok, tank is mounted and kickstand bud is on.
Might do some stainless spokes over the winter. I like shiny spokes.
I also tackled the left side of the tank. As careful and skilled of a welder I am (not an expert), I was chasing more pinholes than I wanted to. I had to curve the petcock reserve tube just a hair.
Offline cosworth
« Reply #8 on: Apr 09, 2014, 15:00:26 »
Did some digging through my paypal and found it:
http://www.ebay.ca/itm/Yamaha-Virago-XV-250-125-Speedometer-ASSY-Meter-km-h-/260755144139
This link will expire eventually so here is the text from it:
Yamaha Virago XV 250 125 Speedometer ASSY Meter km/h
Item # 260755144139
Here is the seller:
http://www.ebay.ca/usr/kakahc?_trksid=p2047675.l2559
I'm inclined to buy another one for a future yamaha build.
Offline Barkingmadspeedshop
  • Sell the many to fund the few
« Reply #9 on: Apr 09, 2014, 18:24:45 »
Nice work 8)
1981 SR250 cafe             1980 SR250
1971 CB100/200 Cafe      1983 XT550
1977 KZ200 Cafe             1978 CB125S
1978 KZ200
1978 KZ200 Hack             1990 CB125t
1977 XS650 bobber          1999 GSXR600
1978 XS650 bobber          2006 KTM450/525 SMR
1978 XS650
and a bunch of others....
