Author Topic: Hollywoodmx's XV920 Tracker - Quick Build  (Read 43441 times)
Offline HollywoodMX
Re: Hollywoodmx's XV920 Tracker - Quick Build
« Reply #20 on: Apr 28, 2014, 00:09:07 »
Everything is level!  8)
TR1 Build thread: http://www.dotheton.com/forum/index.php?topic=54733.0
Xv920 Tracker thread: http://www.dotheton.com/forum/index.php?topic=59754.15
77 KZ1075 Supercharged - 81 Yamaha XV920rh (x2) - 06 YZ250 highly modified - 08 Hyabusa
"I live my life a 1/4 beer at a time"
Offline wynand2000
« Reply #21 on: Apr 28, 2014, 05:44:05 »
Looking good!
Offline Djfob
« Reply #22 on: Apr 28, 2014, 12:32:32 »
You weren't kidding when you said quick build, looks like you'll be ready to ride in no time. Weather is getting better in the yyc.
78 Honda CB750k
Offline HollywoodMX
« Reply #23 on: Apr 29, 2014, 02:04:21 »
I now know why these pro builders like to work on the same bikes. Makes lifer easier. Ya i need it done by may 15th if I can. Save some final touches and graphics.
Cleaned up the tank which will also double as a mount.
Offline HollywoodMX
« Reply #24 on: Apr 29, 2014, 02:16:50 »
The hardest part of the subframe done. Getting the first frame tabs welded for the two poles and being true and level. This is why the measuring is so important.  So the last pic the level is nice and green and the front of the seat is nice and flush t the tank. :-)
Offline wynand2000
« Reply #25 on: Apr 29, 2014, 03:33:28 »
Nicely done with the tabs and tank, on my tank I bended over all the welds towards the tunnel first before welding.
This makes it possible to use less putty to smoothen , but I guess you could even let the seam like this?
Offline HollywoodMX
« Reply #26 on: Apr 29, 2014, 13:26:15 »
Thanks man. Ya i needed the extra length of the tank welds to meet up to the seat properly. The longer the tank the lower the seat will be and this bike is being designed for a slightly lower seat height than average if I can help it.
I have bondo and long hair fiberglass putty. Which would be better to smooth out the tank transition. I was thinking of using the the long hair to fill the big gaps then bondo to get it smooth.
Offline HollywoodMX
« Reply #27 on: Apr 30, 2014, 15:15:21 »
There goes the neighborhood!
Offline wynand2000
« Reply #28 on: Apr 30, 2014, 15:23:29 »
You`re taking a sprint ! ......impressed!
Offline dualero
« Reply #29 on: Apr 30, 2014, 16:49:10 »
Why did you made that last cut on the frame? Cool fast build, keep it going!
DH900sl
