Author Topic: Blue Haze - a two-stroke miscellany  (Read 92643 times)
Offline CrabsAndCylinders
Re: Blue Haze - a two-stroke miscellany
« Reply #470 on: Jun 16, 2017, 15:00:34 »
This maybe?
Lighter, Quicker, Faster.
Offline Hurco550
« Reply #471 on: Jun 24, 2017, 23:55:48 »
Went up to a memorial service for a snowmobile buddy of ours who recently passed of cancer. Many people showed up in all manner of vehicles, but this one obviously caught my eye. All original first year buffalo. Survivor barn find with somewhere around 7k miles. Not perfect, but a very neat bike!
Sent from my SM-G900V using Tapatalk
~ bradj
Offline cobraace2
« Reply #472 on: Jul 24, 2017, 11:26:33 »
Highwayman LSR I know this guy his work is incredible
notice the port work pictures do not do it justice
Offline cobraace2
« Reply #473 on: Jul 24, 2017, 11:39:56 »
notice how the studs get ported to ;)
Offline teazer
« Reply #474 on: Jul 24, 2017, 13:05:26 »
Amazing work.  Can someone explain what he has done and why?
It looks like he took two sets of TZ250G barrels (with fat intake ports stock) and welded in a bridge in the intake and then added reed boxes and rear boost ports.
On the exhaust side he appears to have added a pair of eyebrow ports for more initial time-area and more blowdown T-A.  And he's machined up some new studs to provide space for those extra ports.  But the exhausts are extremely wide and those oval outlets are not stcok on those barrels.  That's an interesting mod.
The reshaped front (main) transfer port was either been welded to allow sufficient bridge to the exhaust ports or has been raised and that would be unusual, so I'm guessing they were also welded.
The welding along the front lower flange and machined away water jackets are very interesting.  Is he running it dry and arranging to have forced air to stop it melting on a long run?  That I don't get. on an LSR bike, weight is less important that power and drag, so there's some thinking that isn't obvious.  If it's to be aircooled, would it not be easier to start with an RD250 barrel or would that need even more welding and machining to work?
Offline Redbird
  • Dolor est Magister Optimus
« Reply #475 on: Jul 24, 2017, 14:31:59 »
And, forgive my ignorance, but wouldn't sectioning out the head studs be counterproductive to the clamping strength?
For clarification, I'm not bashing/flaming, just trying to understand.
When you are Dead, you don't know that you are Dead. It is difficult only for Others.
It is the same when you are Stupid.
Offline teazer
« Reply #476 on: Jul 24, 2017, 15:59:22 »
Short answer is yes, but how strong do they need to be?  I don;t know but I am guessing that Jeff Henise will soon find out. He still has to cut or roll threads and work out what he's doing about the sleeve nuts.  My guess is he won't use them but will use simple nuts on top of the head.
Those studs look more like 10 or maybe 12mm diameter so it's also possible that he moved them slight outwards at the same time as going up from stock 8mm. The cutaways look to be in odd places and direction but we can't see the ports in relation to them
Offline DesmoBro
  • Busted Nut
« Reply #477 on: Jul 24, 2017, 21:37:02 »
Im tryin squeeze every last ounce outta this stock bore moped....hoping to see 60 mph then apply same shit to this 4 speed bottom end to try and hit 100
"I desire the things that will destroy me in the end"
Offline BillyGoat4130
    • Live Oak FL Real Estate
« Reply #478 on: Jul 24, 2017, 22:59:17 »
Some of ya'll seen it in the specials section already I'm sure, but I sure do like staring at this thing!
The question isn't who is going to let me, it's who is going to stop me.
You can't reason with the unreasonable.
Too dumb to quit.
Insta: https://www.instagram.com/hondaatc/
Photography: http://wgolightly.smugmug.com
Real Job: http://landsofnorthflorida.com
Offline Hurco550
« Reply #479 on: Jul 24, 2017, 23:04:43 »
I like starting at that thing too.
~ bradj
