Author Topic: New Jersey sr500 tracker/scrambler  (Read 89225 times)
Offline Tune-A-Fishİ
Re: New Jersey sr500 tracker/scrambler
« Reply #770 on: Sep 30, 2016, 22:25:23 »
Scrap from the base gasket up  ??? Maybe the jug is salvageable, but why bother.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #771 on: Oct 01, 2016, 03:06:31 »
Kamn is gonna be sad cuz you need to take the motor from his SR
Offline cxman
« Reply #772 on: Oct 01, 2016, 09:33:11 »
with all the ground up metal that has gone thru the pump back thru the motor
its a lawn ornament or needs more new parts than you can imagine
bet its easy to find a new oil pump ???
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline JadusMotorcycleParts
    • Jadus Motorcycle Parts
« Reply #773 on: Oct 06, 2016, 16:13:48 »
Make sure you tight everything or else... the piston is also melted to the connecting rod -_- who has replacement parts :)
Wait, what happened?
Offline Nj732port
« Reply #774 on: Oct 10, 2016, 08:54:43 »
I have a dual oil feed to the head, the exhaust banjo bolt backed out I replaced the banjo bolt and crush washer not realizing there were two crush washers, I had an oil leak, then I had no oil, then things melted :(
« Reply #775 on: Oct 10, 2016, 08:57:46 »
Oh sucks man.  Hope you can find some parts or even a decent second hand engine!
Offline Nj732port
« Reply #776 on: Oct 10, 2016, 09:03:20 »
thanks I been hunting for one
« Reply #777 on: Feb 15, 2017, 11:47:34 »
Done yet
Offline redwillissuperman
  • Keep it simple- engine, wheels, bars
« Reply #778 on: Feb 15, 2017, 19:29:52 »
Yeah its not bad, kinda sucks to paint the underneath unless you can prop it up higher than how I had it. Make sure you make the spacing between the boards +2-3"  on either side so you can get the sidecovers on and off if you gotta.
You can also buy 4 extra bolts and thread one on each side of the engine and snug on the cases so it doesnt slide back and forth on the rods. Wish i thought of that last week.  ;D
Another option is to dangle from Engine Lift. Easy to adjust height and spray underneath.
