Author Topic: 1948 HRD Vincent -Ashtray to Driveway  (Read 30416 times)
Offline brt651
Re: 1948 HRD Vincent -Ashtray to Driveway
« Reply #100 on: Jun 12, 2017, 03:42:47 »
Hi Guys,
I'm glad your enjoying this build. I've been waiting since December for clutch arm parts. I have done some assembly but not much. I'll put a picture up soon as the parts i'd been waiting for arrived on  Thursday.
I'm also looking at doing an Egli-Vincent build. I'll know more tomorrow.
Cheers
Brt651
Offline brt651
« Reply #101 on: Jun 12, 2017, 04:07:32 »
Hi again brt651,
Have you fitted the primary cover yet over the Bob Newby belt drive? I just tried on my Black Shadow and failed even though I have machined away the wall between the clutch and the clutch sprocket.
I have posted my project on http://www.accessnorton.com/crankcase-repair-t24312.html
BR / Patrik
Hello Patrik,
Sorry for the late reply.
I haven't covered the belt drive as yet. I'm waiting on an aftermarket clutch cover to butcher.
Ive just read your posts on the Accessnorton site. I liked it very much. Your well on your way.
Good luck with it all.
Cheers
Brt651
P.S I like your conrod protectors. I seem to have seen them somewhere else. ha ha
Offline buellingvincent
« Reply #102 on: Jun 12, 2017, 05:31:17 »
Hi Brt651,
Thanks! The conrod protectors was your idea. I read your post and copied  :)
I just came back from the Scandinavian Vincent Club Rally. I brought the engine with me in the car and had great discussions with several members. Ernst Hegeler, a German who owns a genuine Black Lightning, makes new crank cases and covers and have built a few engines with electric starter with the starter motor located where the dynamo normally sits, told me that I need to machine the inside of the cover as much as possible to make room for both clutch and belt. If I don't do that my 30mm belt won't fit under the standard primary cover even if I put the pulleys as far in as possible, unless I make a 8mm spacer between the crank case and cover. I might still need to make a thin spacer.
Another member who had managed to fit a Newby belt under a standard cover also machined the inside of the cover but before that he had the cover welded on the outside to add material. This is according to him a must to avoid using a spacer all together as there is not enough material to machine away as needed on the inside to make room for the belt.
I was also told that when putting the clutch as far in as possible the clutch shaft will need to be shorten.
So my next step is to measure as good as I can how much I can machine away on the cover and still have 2-3mm of wall thickness. If the result is that I still need to add a spacer I will probably instead go to the welder and have him add material on the outside of the cover and the smoothen it to make it look stock.
All the best / Patrik
« Last Edit: Jun 13, 2017, 13:54:52 by buellingvincent »
Offline brt651
« Reply #103 on: Jun 12, 2017, 06:22:01 »
Hi Patrik,
Ive fitted a 40 mm belt drive. I'm going to make a spacer with using an old cover I think.
At least you woul;d have had a great day out talking Vincent's. I don't have anyone close I can chat too. Though saying that terry prince only lives 60 miles away.
Cheers
Brian
« Reply #104 on: Jun 13, 2017, 02:08:32 »
Hi Brian, I will use a 40mm belt on my other engine (TPV top end 92 bore and 100mm stroke). I will fit that engine in a Egli-like frame that I plan to make myself. Reading worntorns Vincent 1360 thread on accessnorton.com I'm quite certain that with a 40mm belt a spacer is always needed.
Yes some 60 Vincenteers attended the Rally so many discussions indeed. I'm as far away from Terry Prince as possible living in Stockholm. Both of you are really living down-under from me. No nearby Rallies during your summers?
/ Patrik
« Reply #105 on: Jun 13, 2017, 13:49:12 »
Hi again Brian,
Handed over the cover to the welder this morning. He will try to have it ready next week.
Will focus on fitting the gearbox the comming days. Plus figure out what I need to do to place the pulleys as far in as possible.
Offline brt651
« Reply #106 on: Jun 14, 2017, 09:15:07 »
Hi Patrik,
Good luck with that. It seems a long time ago since I fitted this gearbox. I fitted a 5 speed from Quaife. I made steel spacers for the seals to run on instead of the alloy ones Bob supplies.
Cheers Brian
Sent from my SM-G900I using DO THE TON mobile app
« Reply #107 on: Jul 05, 2017, 12:44:00 »
Hi Patrik,
Cheers Brian
Hi Brian,
I got stuck a bit with the gearbox as I realized I need to replace the bushes on the final drive shaft. Still waiting for those two pieces.
Instead I've spent hours on the Newby clutch hub and many hours on the primary cover. I have finally machined the inner end of the clutch hub to make it slide over the shaft splines and sit tight to the PD21 spacer. Shortened the splines of the clutch hub by 4mm and chamfered it so now it is almost 10 mm further in. The cover primary is now reshaped and the 30mm belt fits under it without any need of a spacer between cover and crank case. A hell of a lot work to get there.
However I needed to order a bigger crank pulley (40t instead of 36t) and a longer belt (112t instead of 110t). Waiting for these as well...
My original cover next to the new reshaped one.
« Last Edit: Jul 06, 2017, 04:37:50 by buellingvincent »
Offline brt651
« Reply #108 on: Jul 09, 2017, 08:15:17 »
Hi Patrik,
I can appreciate the time it takes to modify and make it all work. I have 3 of Bob's belt drives now. I bought extra 30 mm pulleys and belts. I like the way you have got the original primary cover to fit without a spacer. That's a lot of machining.
Keep me up too date
Cheers Brian
Offline brt651
« Reply #109 on: Sep 30, 2017, 04:04:43 »
Hi Everyone,
Well I have been busy fitting parts. I have the gear change,selector, kick start cover and gears assembled. I fitted the exhaust today. That's a nasty job but anyway.
Just have to still fit the tank brackets.
That rear guard took me nearly 50 hours all up. From polishing to making brackets fit and matching the 2 pieces together.
Not to mention all the bracing that goes under the guard plus the tail light assembly and rear stand brackets. I'm not complaining really. also you may notice I have an Egli style frame too now. Actually I bought 2 off them. But that's for another time.
Cheers
Brian
