Quantcast
Author Topic: 1948 HRD Vincent -Ashtray to Driveway  (Read 31977 times)
Offline trek97
Re: 1948 HRD Vincent -Ashtray to Driveway
« Reply #110 on: Sep 30, 2017, 05:42:35 »
Hi, just now found and read the whole thread.  Absolutely stunning work on a very neat machine.
Offline 3DogNate
  • "You Meet the Nicest People on a Honda"
« Reply #111 on: Oct 10, 2017, 21:42:45 »
Sick ain't it? I need more... it's been a while
Offline brt651
« Reply #112 on: Apr 29, 2018, 02:14:11 »
For those of you loyal followers please don't give up hope on me finishing this one. There have been a few problems recently that have been over come and I should be full steam ahead again. I'm seeing what troubles I come up against fitting these dellorto carbs today. Looks like the tank will need to be modified. Thank you again for looking.
Sent from my SM-G900I using DO THE TON mobile app
Offline The Limey
  • Evil English Villain
« Reply #113 on: Apr 29, 2018, 05:16:49 »
Oh my days.  Full frontal porn so early in the morning!
Offline datadavid
« Reply #114 on: May 04, 2018, 08:46:19 »
Looking good Brian!
I also got a bit further with my bike. Hope to get the top ends bolted on this weekend and start putting the timing side parts back again.
A picture of a the primary cover just hanging in the belt.
The outside of the pulley is now only sticking out about 17 mm (2/3").
Perfect solution to the messy stock clutch.
Offline brt651
« Reply #115 on: May 06, 2018, 04:28:02 »
Hello Buellingvincent ,
Glad your making headway.
The space you have looks great. I've had to make up 26 mm spacers to get clearance on the belt for now. I've ground away a lot of the primary cover also.
My next task is to remove some of the fuel tank for clearance on the front carb.
Then run the oil return lines and fuel taps and lines.
THEN think about firing it up!!!!!
I bet there are a few followers that wish I just got in and had it running. I'm keen too. ha ha
Cheers
Brian
Offline buellingvincent
« Reply #116 on: May 07, 2018, 04:34:18 »
Thanks Brian,
You have a 40 mm wide belt if a remember. I believe that one will never fit under the cover without a spacer. I have a 30 mm belt and had to squeeze it in.
Good luck with the tank Brian!
/Patrik
« Last Edit: Jun 13, 2018, 06:25:22 by buellingvincent »
Offline brt651
« Reply #117 on: May 12, 2018, 10:12:14 »
It's coming together nicely. Good luck with the timing. All my gears are new and no timing marks. It's very time consuming. I think you will be passing me soon. I better get too it.
« Reply #118 on: May 18, 2018, 18:08:48 »
Thanks Brian,
Doing my best. Much more progress now when I don't only have to repair/modify/fix things. More fun as well.
Patrik
« Last Edit: Jun 13, 2018, 06:31:05 by buellingvincent »
Offline 3DogNate
« Reply #119 on: May 28, 2018, 11:55:19 »
schwiiiing! looking good man!
