Author Topic: 1948 HRD Vincent -Ashtray to Driveway  (Read 27339 times)
Offline brt651
Re: 1948 HRD Vincent -Ashtray to Driveway
« Reply #80 on: Apr 03, 2016, 05:35:42 »
Hello Everyone,
Thanks for looking
Offline Tune-A-Fishİ
« Reply #81 on: Apr 03, 2016, 10:37:05 »
Oh boy is that beautiful.
Unubtanium for my lil hobby :-\
Offline palepainter
« Reply #82 on: Apr 03, 2016, 11:41:36 »
Ya man.  Talk about embarking on an adventure. Incredible read and build.
Offline lostboy
« Reply #83 on: Apr 03, 2016, 12:05:41 »
That front fork is absolutely gorgeous. Very nice!
Offline dorteerts
« Reply #84 on: Apr 04, 2016, 07:52:34 »
 :P
Pity it will be decades before any of the Vincents or the Goldie will be finished!!!!!!!!
A few old ones and some new stuff.
Offline buellingvincent
« Reply #85 on: Jun 21, 2016, 15:44:09 »
Hello Again,
  Firstly because I'm fitting a belt drive and secondly this was a modification done by the factory in around 1951 on the 500. I'm fitting a seal and I need a seal holder. The seal holders I have are the genuine style. But, I have a back to back Timken Taper bearings fitted to the left side of the crank. Originally it has a ball bearing outer most ( which controls crank end float) and the other three crankshaft bearings are roller type. I show the area in the photos, along with my drilling guide and seal holder. I'm not going to use this seal holder as I want it to place some pressure against the taper bearing cup and come outwards from the bearing as well. As I have more clearance with the belt drive than I would if I where to use the original chain primary drive. And since I have 2 engine with this set up I'll be getting 2 made.
   And for those that notice the orange square outline. This is a marking that is stamped into the cases. To check that they are a matched set. Very hard to see. But this unique marking is in the 2 crank halfs,primary cover ,G2 cover. I don't know what the stamping means. Maybe the bloke that assembles the engine has his own stamp?
   Well this is as far as I've got. I''ll get some more pics up as I get more done. Off to lap the pushrods in.
  Cheers
      brt651
Hi, Working on three Vincent engines in parallel? Impressive! Good work indeed.
I will also install a pair of taper roller bearings in my Black Shadow and will omit the outer circlip as I also have a Bob Newby belt to be fitted. Thought I could use the standard seal holder from VOC Spares. Did you make your own?
Did you put the taper roller bearings in O or X arrangement? Could you advice how you came up with the width of the two distance pieces between the two bearings to get the right side play?
/ Patrik
Offline goldy
« Reply #86 on: Jun 23, 2016, 09:08:07 »
Some pretty impressive work! Again...I keep looking for the "like" button. ;)
1948 Norton ES2
1955 AJS 20B
1956 Triumph TRW
1968 Triumph T100 special
1969 Norton Commando
1975 XS650 Yamaha
Offline 3DogNate
  • "You Meet the Nicest People on a Honda"
« Reply #87 on: Jun 25, 2016, 00:16:35 »
man o man
Offline brt651
« Reply #88 on: Jun 26, 2016, 03:09:03 »
/ Patrik
Hello Patrik,
I used the VOC seal holder and had a tool for drilling and tapping made. Terry prince setup two engines with back to back taper bearings for me. He only lives 60 miles from my place.I believe Terry has fitted them in an  X arrangement. Much the same as a Harley Davidson uses on the left side of the crank.
I have just finished lacing up the rear wheel and I bought a twin leading shoe front brake set up from France.
I'm trying to make a decision on what tires to fit. I"m thinking of the Race versions of the Avon AM26's. I know they wont last long, but I don't expect to ride them much.
« Reply #89 on: Jun 26, 2016, 08:36:32 »
Those hubs look like rear quick change hubs... interchangeable?
