Author Topic: 1948 HRD Vincent -Ashtray to Driveway  (Read 30465 times)
Offline brt651
Re: 1948 HRD Vincent -Ashtray to Driveway
« Reply #90 on: Jun 26, 2016, 10:13:31 »
Hello T-A-F,
Both wheels are quickly detached , having a tommy bar for an axle. Easily removed by hand. The bike has two front side stands and one rear stand enabling the bike to be suspended off the ground when all three are used at once.
The rear wheel on this model has two sprockets of different sizes fitted. The idea was that when you entered the hills you would simply pull over put the bike on its stand,raise the rear third of the back mudguard as its hinged , detach the quick release brake arms,brake rods and remove the tommy axle. Reverse the wheel fit chain and adjust with the finger dial adjusters,brake rods and brake arms and off you go. While that seems easy it's assembling the wheels that is difficult. As the wheel has many parts that need assembling and eventually becomes a standalone part. I'll explain it later when I put it together and supply photos.
Thanks for your comment
Cheers
Offline andrew6v
« Reply #91 on: Jul 16, 2016, 08:43:30 »
That bike is very cool, can't wait to see the finished product.
Offline brt651
« Reply #92 on: Jul 16, 2016, 08:58:10 »
Hello Andrew,
I'm of a similar view. I'd like to see it finished also. I just ordered a Aluminium tank and with that I have everything now but time. I'm doing the head gasket on my daughters car at the moment. I guess we all have jobs to do outside of what we like doing.
Thank you for your comment
Cheers
Brian
Offline brt651
« Reply #93 on: Nov 07, 2016, 05:10:04 »
Hello Everyone,
Thank you for dropping by.
I have been busy. I've assembled both wheels hubs etc. Assembled brakes and installed the wheels. I still have a lot to do.
Cut the rear guard to fit. Modify rear stay on front guard to fit around the 4LS brake set up.
The rear wheel and handle bars only went on this week. I've ordered fast action throttles. I"m going to buy Dellorto PHM 38 mm Carbs. The Alloy tank you see isn't the first tank I ordered. It arrived all nicely painted. But unfortunately they wrapped it before the clear was dry. Never mind. Another wall hanging. It didn't fit anyway. So I asked them to send me on unpainted and no brackets fitted tank. This is the tank your looking at.Beautifully made I believe. Especially the painted tank. But then again they only charged me $38 to paint it. And Yes they are Harley Drag bars. Please look around in the photos and I believe you will see more than I have said.
Cheers
Christmas is nearly here.
Brian
Offline brt651
« Reply #94 on: Nov 07, 2016, 05:11:24 »
And some more
Offline goldy
« Reply #95 on: Nov 07, 2016, 06:27:36 »
Awe inspiring...wonderful to see this old gem coming back together!
1948 Norton ES2
1955 AJS 20B
1956 Triumph TRW
1968 Triumph T100 special
1969 Norton Commando
1975 XS650 Yamaha
Offline Maritime
« Reply #96 on: Nov 07, 2016, 10:33:09 »
Nice work. looking forward to seeing it complete.
Offline buellingvincent
« Reply #97 on: Jun 08, 2017, 07:34:59 »
   Hello,
  Well  I have the Bob Newby belt drive out and measuring for new distance spacers and a new seal holder. I've been in contact with my machinist and he is up to speed. So its all go ahead.
  then I need to make a new primary cover. I have seen some out of fiberglass ,but they look a bit ordinary. It needs to be alloy and polished. Anyone have one?
  Well that means back to the timing side to finish of the push rods.
    Have a great week
Hi again brt651,
Have you fitted the primary cover yet over the Bob Newby belt drive? I just tried on my Black Shadow and failed even though I have machined away the wall between the clutch and the clutch sprocket.
I have posted my project on http://www.accessnorton.com/crankcase-repair-t24312.html
BR / Patrik
« Last Edit: Jun 08, 2017, 09:38:08 by buellingvincent »
Offline SrgtBear
  • The arsenic has oddly shaped feet...
« Reply #98 on: Jun 08, 2017, 19:30:31 »
I'm sucked into this thread.  Officially subscribed and overly excited to see this beauty come to life!
Ted
Kawasaki Kaiju (怪獣) - 79 KZ650 - 700cc Bore Cam Rocket - http://www.dotheton.com/forum/index.php?topic=39748.0
75 Yamaha XS500B Cafe - Completed - http://www.dotheton.com/forum/index.php?topic=14392.0
74 Honda XL 125 - Original - http://www.dotheton.com/forum/index.php?topic=25706.0
Offline cookiemech
« Reply #99 on: Jun 09, 2017, 06:16:27 »
You're not the only one! Glad this thread popped up.
