Author Topic: XS360 Bratstyle Replica- Codenamed: Sheeple II  (Read 16047 times)
Offline DeanJ
« on: Oct 01, 2014, 11:38:54 »
I drug home this hot little mess a couple of years ago. It's a '77 XS360, the basic entry level model with kick start only and drum brakes front and rear.  The PO was up front about the fact that what's not missing doesn't work anyway and the exact volume of oil you pour in would be puddled on the ground within 15 minutes .  It had a title so I traded him an old  DVD player for it.
Other than the seat being torn up, the rotted mis-matched tires, rusty spokes, frayed clutch cable, broken brake cable , missing brake lever, busted switch gear, leaky forks, missing indicators, busted up pilot light console, vandalized ignition switch, shitty bumblebee spray bomb, wonky kickstand , a 30 amp bullet fuse spliced into each and  every circuit , cheap ass emgo filter pods, dead battery, rusty jardine 2 into 1 pipe, toasted headlight etc. etc. etc. ....   it's in pretty good shape for my next project.
 This is a bare bones budget rescue using only the change in my couch and whatever is lying around my mess of a garage. It will make a fine Sheeple inspired Brat replica  ;D
Here are some "before" photos:
Offline Maritime
Re: XS360 Bratstyle Replica- Codenamed: Sheeple II
« Reply #1 on: Oct 01, 2014, 11:41:03 »
This should be a fun little scoot when you get it done.
Offline Ease
  • 83 XJ650RK, 77 TS-250
« Reply #2 on: Oct 01, 2014, 13:45:43 »
Really digging the original bike/decals.
Get her going!
Offline namelesspenguin
« Reply #3 on: Oct 01, 2014, 14:03:40 »
...It had a title so I traded him an old  DVD player for it.
AWESOME!!!
Offline VonYinzer
« Reply #4 on: Oct 01, 2014, 18:28:53 »
With 19k on the clock, spend some serious time going over that motor so you don't build yourself a pretty grenade.
Offline DeanJ
« Reply #5 on: Oct 01, 2014, 21:39:44 »
Get her going!
I wish it was original.  It was a red bike from the factory, this yellow paint is poo and the kmart stickers have to go !
Ha! It will not be pretty, it will be a sheeple brat replica  and I won't be using that clock anyway.  ;D
In all seriousness, the mileage is totally unknown, the motor had been swapped at some point in it's life and there was no cable in the speedometer housing anyway !   I fixed the oil leaks, did some maintenance, tune and adjustments... I need to upload those photos tonight or in the morning.  It's running and I'm pleasantly surprised !   :D
Offline DeanJ
« Reply #6 on: Oct 01, 2014, 22:53:27 »
Added some oil... and out it came ! I just had to follow  the 20 ounces of red rtv to the leaks  ;)
The alternator wire grommets where they pass through the case / stator cover were a mess and the neutral switch housing was missing the O-ring.
I had O-ring for the switch in a bin and made up a gasket after I Yamabonned the fook out of the damaged grommet
I filled it with fresh oil... and check the compression, 129/131  ,, acceptable on dry, cold cylinders
It had totally wrong hot iridium plugs that I tossed  (on right) , and I spent half my entire project budget on new spark plugs.
I dressed and gapped the points and adjusted the valves after I cleaned the carburetors
ick , more sillycone... this time it was used as electrical tape  :o  I'll clean all this up when I go through the wiring
I had to solder and end on the clutch cable so I could take it out and run through the gears. I went ahead and shortened it for the drag bars that came on it. They are staying
yea, it's an upside down clutch lever...  campy !
cuckoo for coco puffs
I need to make up some short runners for the $1 pods that came with it and do a series of proper plug chops
battery ground  ;D
Offline DeanJ
« Reply #7 on: Oct 02, 2014, 16:56:14 »
As both the high and low beams are burnt, I'm going to mount up a cheap 5" head light I have had sitting around. It was a low wattage 6v Italian copy with a gauge socket in the top. I had already converted it to 12v but have not had a need for it until now. Depending on which I run across first, a cheap mini tach or speedo will dictate what goes in there...  The factory tach had been apart at some point as sounds like there are "cards in the spokes" starting at 4k but I do have a good cable  ;D
The stock  bracket for the 7" head lamp was quite a hunk that also accommodated the horn ( not working) and blinkers ( missing ) instead of the usual fork shroud ears.
Typically the headlight ears are scrap on a custom, however I'm keeping the drag bars in the stock clamps and need to mount the very narrow 5" side bolt housing, so I made up a custom set....  and as a bonus, they will hide the horribly pitted fork tubes  ( a bit too gone for even the aluminum foil & WD40 treatment ) The functional slide area is good as it was protected with a film of oil from the leaky seals  ;D
I had a floor lamp rod in the scrap bin that fits over the 34mm forks perfectly !
Cut that down to a proper length set
cut up some scrap steel and laid down some "fancy boogers"  ( my version of welding )
after some metal finishing and a coat of (something), they will look great
I had a set of ear damper rings and have since drilled the mounting holes for the lamp housing. It looks high, however the tach or speedo or whatever I go with in the top of the housing needs to be visible. I might also add pilot lamps for oil and neutral to the top of the housing vs. adding another bracket.  The shrouds also make the tubes look a bit beefier and I might add some gaiters I have sitting here
So on with the wiring... it is all quite a mess
Offline DeanJ
« Reply #8 on: Oct 03, 2014, 16:55:06 »
I'm going to completely rework the wiring on this bike. What is hooked up is working fine, it's just there are so many splices, evidence of  burned insulation, frayed connections, old tape over older tape and many components that are currently missing with miles of dead end wires...
The blinkers, flasher and auto cancel unit are all completely missing anyway so I'm going to eliminate the wires etc. left behind. The entire binnacle was trashed, so I will pair that back to just the pilot lights for N and Oil, plus an illumination wire for whatever gauge I end up with in the head lamp . The replacement headlight is a single beam, so no H/Lo switch. The original ignition switch was chiseled so only a screw driver was necessary to turn it on. I'm going to use a simple DP/DT keyed ignition switch I have here in a drawer-, so no "park" light position. The front brake switch was busted, so I will just have  the rear ( It's also nice to be able to use front only when a cops going by so you don't illuminate the stop light  ;) )   I already threw out that rat's nest of multiple 30amp bullet fuses, so I do need to spend the other half of my budget on a few blade fuse holders with pig tails.
Here is what I sketched out. I will use stock Yamaha wire colors that future owners will appreciate  :)
Offline DeanJ
« Reply #9 on: Oct 06, 2014, 23:48:18 »
I made an ignition bracket for the new location on the down tube:
It will go here:
ready to cut out:
I will prep/ paint to match whatever I do with the frame finish:
I'm taking my time with the wiring... here are some examples of the random po's bodged repairs and what I believe was insulator damage from possibly a fuse block "fire"  :o
I am soldering in replacements/repairs and heat-shrinking everything
When I re-wired, I also extended the alternator and field coil electricals, so I can hide the connectors under the seat :
Modified rectifier junction :
The original brake switch bracket was broken, I  fabbed up a new one :
