Author Topic: '01 Honda CG125 cafe racer  (Read 7341 times)
Offline twade76
« on: Oct 27, 2014, 20:19:33 »
Hello,
Bought this thing a couple of months back:
It was pretty much done when I bought it, but I've got a few plans for it.  I've just ordered some clip on bars so I can lower the front end a bit and have fitted a shorter chopper pot style exhaust.  Going for a colour change as well, probably metallic green.
Cheers,
Tom
Offline Erskine
Re: '01 Honda CG125 cafe racer
« Reply #1 on: Oct 28, 2014, 20:37:01 »
Lowering the front end makes a big difference, and i'd recommend changing the fork oil while you are at it. Also getting some rear shocks that actually damp! Then you'll be able to make the most of those tyres! Also make sure you use an exhaust that has plenty of back pressure,..... if a cg is loud it means it is producing noise instead of power ;)
Offline twade76
« Reply #2 on: Oct 29, 2014, 18:42:17 »
Cheers,
Just had the forks serviced and they picked up that the stanchions are pitted so I'm thinking of replacing them in the new year.
May change back to the original exhaust, it sounds pretty cool but does feel like it's lost a bit of oomph (not that she had much to start with...)
Offline twade76
« Reply #3 on: Feb 10, 2015, 19:10:04 »
Right then, it's been a while but I've finally gotten around to doing a bit more work on the bike.
Had a few issues with the indicators, ignition and carbs that seem to be fixed so it's back to working on how the bike looks and feels.
I fitted some clip on bars and I've lowered the front end by an inch or so.  She's looking a bit better now, with a straighter and flatter bone line (I've been reading up on the excellent bike exif website: http://www.bikeexif.com/build-cafe-racer ).
After the issues I had with the carb, I decided to splash out on a K&N filter which is working like a dream.
Also just ordered a new seat: http://www.ebay.co.uk/itm/Universal-Cafe-Racer-FLAT-Seat-SCRFUNI-2-ABS-plastic-/141432326725 I decided to go for a flat seat rather than a hump, mainly because I like the look of them but I've also decided to remove the battery so don't need the space the hump gives me.
Finally, I've decided on going for metallic dark green for the tank, it's been stripped down so I'm just waiting for a bit of spare time one weekend to give it a coat of paint.
Hopefully I'll get some time over the next few weeks to put it all together and then I'll get a couple of pics up on-line.
« Last Edit: Feb 10, 2015, 19:11:43 by twade76 »
Offline twade76
« Reply #4 on: Mar 01, 2015, 14:15:49 »
 Had a bit of time this weekend so finished stripping down the tank and got it sprayed up:
I've also cut down the seat I bought and put them onto the bike to get an idea of how it'll look:
Just need to work out the best way to secure everything and keep the wiring hidden and protected!
Offline Maxd22
  • Dumb kids
« Reply #5 on: Mar 01, 2015, 14:21:56 »
Those few changes that you made really spruced her up, looking good! What are your plans for the cockpit?
We're just dumb kids until we find a way to do it better
CB200 build: Hephaestus
http://www.dotheton.com/forum/index.php?topic=53073.0
Offline twade76
« Reply #6 on: Mar 01, 2015, 14:47:51 »
Cheers  :)
I've bought some alu plate and that I'm planning on making a mount for the ignition. indicator and neutral lights.  I've been trying to find a low-profile speedo to try and keep swoop clean but I'm having difficulty.  might just have to drop it as low as I can behind the head light and work the ignition etc. around it.
Offline Titan performance
  • Titan cafe racer builders.
    • Titan Performance
« Reply #7 on: Mar 01, 2015, 15:31:54 »
I'm helping a mate build a CG 125 cafe at the moment, so always keen to see what others are doing. You definitely made an improvement dropping the forks through the clamps...we did the same, and also fitted some slightly longer rear shocks to get the back higher than the front, for a racier look. We are also making a high level exhaust, and rearsets. You may find your feet are too far forward with the clip-ons. We dumped that cross member footrest arrangement, along with the main stand, but you also then lose the prop stand too....so today, we made a new prop stand mount to fit to the right side of the frame, as mounted on the left, it would foul the chain run.
Nothing is simple, but I guess if it was, everyone would be doing it !
Offline grandpaul
  • Author, "Old Bikes"
    • Born Again Bikes
« Reply #8 on: Mar 01, 2015, 15:36:52 »
Don't take this personally, but I liked the old look better.
I do like the COLOR, though.
It ain't braggin' if ya done it.
Offline twade76
« Reply #9 on: Mar 01, 2015, 15:54:48 »
No problem grandpaul, beauty is in the eye of the beholder! The colour is British Racing Green.
I'd be interested to see your footrest arrangement Titan, I don't have access to any substantial machining or welding gear though so I might have to stick with what's there. It would be good to see the high level exhaust as well, I really like them on bigger bikes but I haven't seen one on a 125 yet.
