www.Moto-Madness.com
Author Topic: '74 CB 360 Cafe Build - Luna - "Done"!  (Read 63145 times)
Offline crazypj
Re: '74 CB 360 Cafe Build! (the beginning)
« Reply #30 on: May 13, 2015, 17:51:41 »
Does it have memory to prove how fast 360 is?  ;D
I'll get tach plugs in the mail tomorrow
Best thing I ever overheard
Brian Morgan, 1982
Offline Sonreir
  • Moderator
  • Oregon
« Reply #31 on: May 13, 2015, 17:55:48 »
I don't think so, but there's a phone app for that.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline trek97
« Reply #32 on: May 13, 2015, 23:08:02 »
You can get all kinds of options on those things.
0-60 time
1/4 mile time+speed
top speed
average speed+distance
compass
elevation
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #33 on: May 14, 2015, 22:35:02 »
Would be nice to be running one less cable but I've got too many parts on order. Plus I'm kinda fond of that hunter green on the OEM speedo
Still cleaning the inside of fuel tank. Had to re-soak with acetone to remove some of the loose red kote, followed by warm water and simple green. Full of phosphoric acid as we speak for surface rust.
While waiting for my electronics pan and rearset mounts to be cut, got a little idea to mod the original rear inner fender. Planning on using the cutout as a mold to lay up some fiberglass. Traced some quick sharpie lines and hit it with the dremel and voila!
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #34 on: May 15, 2015, 12:54:34 »
Had some time before work this AM. Finished prepping the inside of tank, dried it out (hit er with the leaf blower then heat gun). Filled her up with some sparkly POR15. Hopefully this stuff holds up, got too many hours into this fuel tank right now
Getting organized for crankcase reassembly.
Offline Ellwood
  • Vintage person on vintage bikes...
« Reply #35 on: May 15, 2015, 15:10:40 »
POR15 tank seal is the best. I had one tank with it and it looked like a factory new tank. Aaron now has my bike and I bet it still looks perfect.
Adult onset Attention Deficit Disorder is my cross to bare....
Offline crazypj
« Reply #36 on: May 16, 2015, 02:00:25 »
No idea what's inside the tank I'm using.
 Looks terrible, sealed over the rust and god knows what else, works fine thugh without any build up in filters or carbs
 Make sure tensioner pivot is free to move while you have things apart
Brian Morgan, 1982
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #37 on: May 16, 2015, 21:02:37 »
Got the lower and upper halves of the case reassembled. Kick start mechanism functioning properly, oil separators and tensioner push bar installed in the lower. Gearshift mechanism, transmission main shaft and countershaft with new oil seals, cam chain, and tensioner reinstalled.
Shifted through the gears and everything's nice.
@PJ - Are you referring to where the tensioner pivots on the dowel? If so it is oiled and moves freely.
Offline crazypj
« Reply #38 on: May 17, 2015, 00:12:15 »
Yep, all good
Brian Morgan, 1982
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #39 on: May 17, 2015, 21:39:20 »
Sealed the cases this morning, reinstalled the oil pump, pickup, clutch and idler gear. Couldn't find the updated oil pickup so I'll just be keeping a close eye on the oil for now until one comes up on eBay. Fitted HD clutch springs courtesy of bore-tech, keeping OEM friction plates and discs until I burn them out.
I'm deleting the electric start (save your flames, I know it's a "stupid" mod), and I've removed both of the starter gears and the starter clutch. I've seen the alternator rotor milled or filed down to "balance" it once removing the clutch. Is this absolutely necessary or is it acceptable to reinstall the rotor without removing the mounting tabs for the clutch?  Is there a noticeable imbalance when the motor is running?
Edit: photos
-N
« Last Edit: May 17, 2015, 21:41:18 by adventurco »
