Author Topic: Yet another SR250 Tracker UK Build  (Read 19001 times)
Offline vortexracing
Re: Yet another SR250 Tracker UK Build
« Reply #50 on: Apr 27, 2016, 16:18:57 »
Well carb cleaned with the aquablaster and all hardware re-plated and then rebuilt      :)
IMG_8099 by eastham_david, on Flickr
« Reply #52 on: May 07, 2016, 16:59:46 »
fuel tap cleaned and blasted now     :)
Untitled by eastham_david, on Flickr
Online JadusMotorcycleParts
    • Jadus Motorcycle Parts
« Reply #53 on: May 08, 2016, 05:30:30 »
Hey man, by aqua blaster, do you mean water blaster or soda blaster?  Or something else entirely? Cheers
« Reply #54 on: May 14, 2016, 04:41:48 »
not sure, but it's a 'Vixen Aqua Blaster'
Offline Tune-A-Fishİ
« Reply #56 on: Jun 25, 2016, 17:23:43 »
I just love the vapor blast finish so clean
Offline beachcomber
  • TJ - Beachcomber
« Reply #57 on: Jun 27, 2016, 05:34:13 »
I had one of these systems years ago when I was manufacturing replica Sports cars. It used glass bead mixed with water. The ued bead / water was collected into a hopper and dried off before being recycled.
You can buy soda / sand blast pots for around £150 - £200, but it's an open air total loss system ! They give the same sort of results as shown in this thread.
Excellent work so far BTW. 8)
« Reply #58 on: Nov 23, 2017, 17:10:39 »
Well we at off again, other things have got in the way, but the engine re-build has started.
The bad news is it's 2 years since I stripped it and I'm struggling to remember certain bits   :(
Some help would be much appreciated gents.
Firstly, the hole in the threaded head above the crank centreline, does anything go in it?
and 2ndly I seem to have two bolts left over. The problem is I bagged a load of them up and sent them all for blasting and plating, silly mistake.
one looks like M4 and the other is M5, can anybody shed a light on where they go?
and 3rdly
Does the top ring (I think its the top ring) sit with the larger dia on the bottom? ie as in the Photo
Thanks in advance
Dave
« Last Edit: Nov 23, 2017, 17:28:52 by vortexracing »
Online Pete12
« Reply #59 on: Nov 23, 2017, 23:19:07 »
Not sure about your bolts and hole but the manufacturer's stamp on the piston rings (adjacent to the gap or end) always goes up.
