Author Topic: $50 mod thread  (Read 372779 times)
Offline JRK5892
    • The Powder Pro
$50 mod thread
« on: Dec 09, 2008, 17:19:58 »
Painting Wheels - JRK5892
Helmet Bump Stop - halfton / autoguy
Home-Made Risers - JRK5892
Cheap Wire Clean-Up (Wire Ties) - JRK5892
Bearing Ring Removal Tool - Bouncer
Stripping Paint from a Tank - JRK5892
Removing Powder Coat - JRK5892
Installing Clubman Bars - Flugtechnik
Headlight Bucket Mod to Fit Speedo - liam
Aluminum Cafe Seat (No Welding) - mrkil
Motor Install / Frame Protection - JRK5892
Relining Brake Drums  - Wee Todd
Helmet Foam for Seat - sgt. slick
License Plate Bracket (with Light) - mysta2
Repacking and Packing Baffles - souperman
Cutting Stock Brake/Clutch Levers - JRK5892
Switch Housings Clean-Up - JRK5892
Building Solid State Replacements for Old Selenium Rectifiers - liam
$2 Bridge Rectifier - johnson_steve
Bike Table - JRK5892
Work Bench - Bouncer
Oxalic Acid to Clean Chrome - njsoccerguy
Lighting - BigBSBusa
Managing Your Bike's Amps - johnson_steve
Bar End Mirrors - Flugtechnik
Tail Light - CThor
Cable Covers - JRK5892
Rolling Bike Stand - mbrown67
Tail Light/License Plate Bracket - Useful Idiot
Homemade Manometer - Useful Idiot
Storage for Bike - Useful Idiot
Custom Cut Shapes Into Cases - Bouncer
Manometers - HerrDeacon
Crazy Glue Stitches - Troybilt
Starter Button Repair - 904cafe
Reproduction Switch - Terry
Ignition Switch in Headlight (Mini Guages) - anarki650
Handle Bar Key Switch - Terry
Engine Stand - Bouncer
Custom Seat - jfsebastian
Aluminum Finish Spray Paint - CresentSon
Koozie Seat - Herm21
How to Cover Koozie Seat - Herm21
Cutting Threaded Rod - Jason TEAMSHRALP
Lightweight Corrosion Proof Battery Box - Swagger
Drink Shaker Muffler Mod - loudest143
Soda Blasting for Carb Cleaning - Terry
Plasti-dip Coating - brewtown16
Lemon Juice Carb Clean - Swagger
Lemon Juice Carb Clean - JRK5892
Shock Spring Removal - IMOALE
Evapo-Rust Rust Removal - VonYinzer
Shaker Muffler Mod - Jason TEAMSHRALP
Ford Regulator - CresentSon
Chrome/Black Cable Wraps - JRK5892
$8 Battery Tender - JRK5892
Rubber Revitalizing - Zixxerboy
CB450/500 Torsion Bar Tool - Useful Idiot
Coil Power Mod (Getting Full Power Out of Your Coils) - Gryph
Metal Scrap Pick-Up - jason TEAMSHRALP
Rattle Can Spray Gun Attachment - CThor
LED Gauge Bulbs - Flugtechnik
Flexi Hose (Cable Covers) - MN_TX650
Taping Rims to Paint Spokes and Hubs - tamickler
Cheap Battery Acid Overflow Tank - Autoguy
Aftermarket Coils - Honda CB450 - krukster86
Clubman Internal Wire - magnang
Profile Holes - Swagger
Epoxy Painting Lowers - JRK5892
Cheap Motorcycle Lift - JRK5892
Vibration In Bars Removal - Swagger
Cheap And Effective Method Of Cleaning A Tank - diesel450
Bluing, It Coats And Seal Gun Barrels - Terry
Free 'Bar-End' Mirrors - overdraft
Make Your Own Idiot Light Dash - HERM21
Keep Zip Ties From Moving Around - TDC
Radio Shack Idiot Lights - JRK5892
Small Bright Led Turn Signals - Swagger
Free Manuals - VonYinzer
Homemade Spring Compressor - goodfornothing
Rust Remover - Swagger & boingk
How to Strip and Paint - dixiedevil
LED Headlight Conversion - JRK5892
Metal Polish - malloy
LED Brake Light "How-To" - crazypj
Custom Paint With Rattle Can (Rattle Can BLING BLING) - tWistedWheelz
Homemade Baffels - Twistedwheelz
Under $20 Halo Eyes - my94f2
$2 License Plate Mount - Blake
Strong and Light Fiberglass/CF Parts Without An Autoclave - Swagger
Easy Polish Chrome/Aluminum - msimm43
Polish How-To - Swagger
Fuse Holder - Maritime
New Light For Old Sealed Beam Headlights - Swagger
Cheap Pre-Made Plate Mounts - Swagger
Predone Sealed Headlight w/ Replaceable Bulb - loudest143
Camera Mount - staffy
Other Sites Under $50 Thread
How To Make Your Own LED Headlight - MBellRacing
Motorcycle Table - midnightcafe
Making Cable Ends - Garage Rat
Carb Adapters for Tuning - loudest143
Tire Beads - Swagger
Less Than $10 Headlight Ears - tWistedWheelz
Gas Tank Rust Remover - rjz5400
DIY Paper Gaskets - midnightcafe
Over Flow Bottle Holder - JRK5892
Syphon - interceptor
Spark Plug Tester - interceptor
Butt Joint Welding Clamp - Roc City Cafe
Bending Brake - sebatron
Skateboard seatpan - sebatron
valve spring compressor - Hoosier Daddy
Tank Badge Restoration - bikeboy
Painting Raised Letters - bikeboy
Painting Raised Letters - tWistedWheelz
Stebel Nautilus Airhorn - midnightcafe
Stainless Brake Lines - midnightcafe
Shock adjuster tool - Staffy
Removing Powder Coating And Anodize At Home - Swagger
Steering Stem Locknut Socket - bikeboy
Cloth Covered Wires - Swagger
Adding vacuum ports to your CB450 - Flugtechnik
Media Blasting Box - sxecafe
Paint Stripper - 1911pewpew
Chain Oiler - boingk
Parts/Paint Cooker - Ethanol
Homemade Leakdown Tester - perattzi
Merge Your Headers On The Cheap - hurley209
Spring Compressor - HelthInsXpert
Spring Compressor - bikeboy
Soda Blaster - DP9
Side Mount License Plate Bracket - Wingspan
Tuck And Roll Look - baconpocket
Body Filler Safe Paint Stripper - arcspeedworks
Trip Reset Knob - Nortstudio
Regal Bench Stool - Staffy
$6 Valve Spring Compressor - tsbigdog
NiCd Battery Revival - JohnGoFast
Bike Stand, Upper Fairing Cross-member Swivel, Tank Strap Adjuster - acm177
Reducing Handlebar Vibration - pablohoney
Theaded Inserts - Sunflash
Reducing Handlebar Vibration - JRK5892, richsuz, Swagger
Resistor To Make LEDs Flash - MitchellSK
Front Fender - Rocker
DIY Pro Quality Paint Work - ben2go
Lathe - Sunflash
Work Bench - dynamitedave
Work Benches - ben2go
Bike/Engine Dolly - Swagger
Sturdy Shelves - ben2go
Regal Rolling Stool - Staffy
Brake Light from Turn Signal - vtwin650
Removing Rust from Gas Tank - GLENNWOOD55CAMEO
Spring Compressor - HerrDeacon
Electrolytic Rust Remova - metropolitanhighrise
$6 Shorty Velocity Stacks - montessa172
Home Made Blasting Cabinet - tsbigdog
Valve Spring Compressor - GK
Valve Spring Compressor - Hoosier Daddy
Welder's Mask - RoadRash
No Chemical Tank Cleaning - Hoosier Daddy
Retrofit H4 Bulb into Sealed Beam - crazypj
« Last Edit: Jan 07, 2013, 14:18:56 by JRK5892 »
Joe
"your life is an occasion, Stand up to it"
www.thepowderpro.com
recent builds: Hd street bob, TX cafe, KZ bratt, Goldwing tour, bratt wing, st fighter, road king, vriago bobber, chop, FXD, 1200 sporty, 1200xl sporty, GSXR, Royal enfield.. and more
Offline HerrDeacon
Re: $50 mod thread
« Reply #1 on: Dec 09, 2008, 17:40:41 »
Great idea JRK, I'm hoping to have one or two of these this winter. It will be interesting to see what appears in this thread.
I love cheap and DIY.
Perry
1972 Honda CB350 K4 / 1978 Honda XL250S /1982 Honda MB5 / 2014 Honda CB500X
Offline BigBSBusa
Re: $50 mod thread
« Reply #2 on: Dec 09, 2008, 19:40:55 »
Definitely a good idea.  It can help someone that is not sure how they will do something or give folks ideas they may not have come up with on their own.
BigBS
1974 Honda CB550
1977 Yamaha XS750 - Project Maggie Mae
1994 Kawasaki Ninja ZX11 - Project Raven
1999 Suzuki TL1000R - Project Sable
Offline JRK5892
    • The Powder Pro
Re: $50 mod thread
« Reply #3 on: Dec 09, 2008, 20:02:22 »
ill start
Job: Black spokes
Cost: 10 bucks
HOW TO:
first i washed the whole wheel in simple green (3/1) and water, then used a wire wheel to sand down my wheels.. ensure that l the loose rust is off and gave a good surface for the paint to grab... again washed with simple green mix... from here i wiped the whole wheel down with denatured alchole... then comes the taping... i started with a fat piece of tap between each spoke, from there using thin maskin tape i wrapped each nipple (do this so i you can still tighten and true the wheel) after that i just stated to cover the whole wheel...
I shot the wheel in black rustolem epoxy paint... light coats, VERY light coats, and follow the directions... let it set up for 48 hrs and removed the tape... here are the pics:
Before:
After the wash:
after wire wheel and wash:
Taped up:
with paint on:
final product:
chrome polish to get the chrome back up and BLING'N
Joe
Offline locO leoN
  • administrator
  • Is that the best you got? OK.. now my TURN...
    • DoTheTon
Re: $50 mod thread
« Reply #4 on: Dec 09, 2008, 20:53:52 »
Good Thread.. Love the idea... I STICKIED it...
Offline JRK5892
    • The Powder Pro
Re: $50 mod thread
« Reply #5 on: Dec 09, 2008, 21:04:56 »
Leon... once this starts to grow and get to be afew pages i can organize it and create a index on the first page so it is a bit easier to sort though... we just need people to contribute and it will just EXPLODE with posts! LETS GET EM GOING GUYS!
Joe
Offline boomshakalaka
Re: $50 mod thread
« Reply #6 on: Dec 10, 2008, 02:27:46 »
this is an awesome thread in the making.
Offline autoguy
Re: $50 mod thread
« Reply #7 on: Dec 10, 2008, 02:51:54 »
not my idea twas halfton,s idea , but a sub $50 bump stop made from a german helmet, i used a fiberglass german skid lid from my local harley shop, the skid lid cost me around $35
http://dotheton.com/index.php?topic=4555.0
my bump stop
carpe diem
Offline JRK5892
    • The Powder Pro
Re: $50 mod thread
« Reply #8 on: Dec 10, 2008, 04:51:38 »
nice! it is shit like that, that will make this thread just AWESOME!
Joe
Offline JRK5892
    • The Powder Pro
Re: $50 mod thread
« Reply #9 on: Dec 10, 2008, 12:45:03 »
$3 homemade riser extensions:
ok... here is what you do:
first decide how all you want to go... pull the stock bolt that feeds up from the bottom of the tree and into the stock handlebar clamp... take that to home depot or the hardware store... get a 1 or 2 in longer HARDENED bolt that matches the same threads and demensions just longer... then pick up a box of fender washers that match the bolt (they should be around the size of a quarter or half dollar)... now take a walk over to plumbing and pick up a piece of chrome piping that matches the circumfrance of the washers (the piping that i used was the kind that is under sinks... thin and chrome, it does not bear weight it is just for looks).... last thing to get is a push chrome cap that fits the pipe. ooh ya and some lock tite
Now how to do it:
pull your bars and pull your stock bar clamps off... find the exact center of the push caps and drill that out to match the circumfrance of the new bolts you will be using... measure out how high you want to raise your bars, then just count out the number of washers it will take to acomplish the lift. after you know the amount of washers it will take measure the stack of washers (goes without saying but make sure both of your stacks have the same amount of washers)
cut your plumbing pipe to match the height of the washers, BEFORE CUTTING, put some packing tape around the area to be cut, this will prevent the chrome from flaking, after both peices are cut file down the rough edges and put it all together (use just a touch of marine grease on the washers to prevent any squeeking... just a touch) mine squeeked a bit but my dads and brothers never made a peep... just tighen it all down and there you go! 3 dollar risers! Here is a crude picture to give you a idea
Joe
