www.Moto-Madness.com
Author Topic: And then there were two.. 1976 GT250 Rebuild  (Read 73566 times)
Offline Hurco550
Re: And then there were two.. 1976 GT250 Rebuild
« Reply #40 on: Mar 18, 2015, 10:09:11 »
I bought a few gallons of white vinegar and filled my fuel tank to the top w/ 100% vinegar for 18+ hrs.,then rinsed out the tank real good & after that I flushed it out w/ a gallon of denatured alcohol to dry it up and keep it from flash rusting while it's drying,you'll have a fresh tank inside after that.  ;)
Awesome, Ill give that a try man! Did you flush it out with water after the vinegar?
~ bradj
1973 Ironhead Hardtail: http://www.dotheton.com/forum/index.php?topic=68135.msg788081#msg788081
"much ingenuity with a little money is more profitable and amusing than much money without ingenuity" - Arnold Bennett
Offline Tune-A-Fish©
« Reply #41 on: Mar 18, 2015, 10:30:55 »
A little later, but cool add
Offline Hurco550
« Reply #42 on: Mar 18, 2015, 10:34:55 »
That is a neat ad! It is actually a bit earlier than mine. That has the ram air heads which they did away with for 76 and 77 and after 77 they went to the x7 250?? I believe. Mine is a 76 going on the frame of a 75. The air cooled triples (380 and 550) kept the ram air heads for the duration of their production.
~ bradj
Offline grcamna5
« Reply #43 on: Mar 18, 2015, 11:33:29 »
Yes,the next step after draining all the dirty vinegar(which has all the rust,etc. from your tank in it)is to completely flush the tank w/ lukewarm water(I did mine in the bathtub over the Winter...no wife  :o :D ) a few times before you 'dry' it w/ the denatured alcohol.I also helped it to dry w/ the hose installed on the output of my electrolux vac.
I put the denatured alcohol in As Fast & Quickly as i could after I removed all the rinse water and then quickly swished that gallon around completely in there and drained all that out.
I then started up the vacuum in 'blower' mode and blew high volume air from the vac.(it does warm up too after the vacuum motor gets warm  ;) )into it mostly from the top,and also a little from the bottom tap hole. I liked the clean result !  ;)
Do your Best,no one can take that from you.
Offline Hurco550
« Reply #44 on: Mar 18, 2015, 19:29:08 »
Thanks for that writeup Gracmna5, I will be giving that a try soon!
The original frame is getting less and less parts on it =)
I am getting sold more and more on this aluminum foil and water polishing.
Back of chain guard
Before:
And after:
~ bradj
Offline Hurco550
« Reply #45 on: Mar 18, 2015, 22:04:15 »
And now there is a swing arm =) poof, just like magic!
~ bradj
Offline Hurco550
« Reply #46 on: Mar 19, 2015, 20:39:34 »
Wiring harness on!
~ bradj
Offline ridesolo
  • "Illegitimi non carborundum"
« Reply #47 on: Mar 19, 2015, 21:12:42 »
That little beast sure has a narrow frame.  Are you finding any surprises so far or has everything been a straightforward swap out?
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
These are on a low simmer out in the shop:
'75 Honda CL360: http://www.dotheton.com/forum/index.php?topic=56547.0
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline Hurco550
« Reply #48 on: Mar 19, 2015, 21:15:33 »
Yeah its a small bike really. Everything is swapping well so far. There is one mounting tab on the old frame that isn't on this one. Don't know what it's for yet, but I'm sure I'll find out haha
~ bradj
Offline grcamna5
« Reply #49 on: Mar 20, 2015, 11:40:28 »
How did your airbox mounting work out ?
