Author Topic: Suzuki GT185 1978 build  (Read 12956 times)
Offline Mr Bernzo
Re: Suzuki GT185 1978 build
« Reply #40 on: Aug 22, 2017, 09:02:52 »
Oil tank, chain and chain guard done. Working on the mud guards, side plates and fuel tank now. There's a lot of cleaning, sanding and priming going on.
Sent from my Moto G Play using Tapatalk
Smell that? 2 stroke...
1978 Suzuki GT185, 2012 Husky TE449, 2003 Suzuki SV1000
Online stroker crazy
  • crazy as a fox
« Reply #41 on: Aug 22, 2017, 09:12:14 »
Hope you make it for the DGR!
Crazy
“Ride like the Wind” W.H.
Offline Mr Bernzo
« Reply #42 on: Aug 22, 2017, 17:38:48 »
Crazy
Thanks, so do I. I should be good to go. It's mainly just more paint and polish from here as well as some rear set mounts and linkages. Then maybe some late nights too.
Offline Mr Bernzo
« Reply #43 on: Aug 25, 2017, 17:45:45 »
Removing the original stickers off the tank. Shame, they were in good condition and looked good but the tank needs a re spray. Thinking about replacing them once painted.
Offline Mr Bernzo
« Reply #44 on: Aug 27, 2017, 06:57:02 »
Headlight, electrical and front indicators on today. Tank, guards and side covers are just about ready to paint.
Offline Mr Bernzo
« Reply #45 on: Aug 29, 2017, 10:04:23 »
Fuel tank and side plates prepped for painting. Time to make the 3 different colours of blue all the same. I cut down the rear mud guard by about a third, then sanded and primed. It was bent about 90 degrees the wrong way when I got the bike. Hopefully get the painting done this weekend. Then it's just exhausts and rear sets to go.
Offline Mr Bernzo
« Reply #46 on: Sep 05, 2017, 09:24:20 »
Been bloody cold and wet here in Melbourne. Hard to find motivation to get out in the garage.
Ram Air air filter turned up from the UK today. I removed the original air box from the rubber manifold and replaced it with a pod. The set up on the left is the original. I couldn't find original or after market filter foam for the original air box
Offline Mr Bernzo
« Reply #47 on: Sep 05, 2017, 09:28:23 »
Also made some progress with paint. I wanted to stay with the original colour but add a white centre stripe. First time doing and stripes. Turned out ok, not as good as I was hoping for though. First was a coat of white, then taped up the stripe, metallic blue then clear. Will need to add a couple more costs of clear I think.
Offline Mr Bernzo
« Reply #48 on: Sep 05, 2017, 09:30:50 »
Starting to resemble a motorcycle again now. 3 weeks to go before the DGR ride. Time getting tight. Still need to make the exhaust and rear set mounts, then do the linkages for rear brakes and gears.
Offline goldy
« Reply #49 on: Sep 05, 2017, 09:33:55 »
Things are looking good...I like the colour and the engine ought to work pretty well with the new filter, especially where both carbs are still breathing through a common inlet.
1948 Norton ES2
1955 AJS 20B
1956 Triumph TRW
1968 Triumph T100 special
1969 Norton Commando
1975 XS650 Yamaha
