Author Topic: saving a 1980 KZ750 twin  (Read 71515 times)
Offline irk miller
Re: saving a 1980 KZ750 twin
« Reply #430 on: Jun 28, 2018, 20:56:24 »
Meh, Scotchbrite and a lathe will clean that piston up just fine.  :-*
Offline doc_rot
« Reply #431 on: Jun 30, 2018, 19:09:44 »
Decided to go all in on the engine rebuild. got some cool mods in mind as well. stay tuned.
Offline irk miller
« Reply #432 on: Jun 30, 2018, 20:33:22 »
In a way, I kinda love being forced into a rebuild and bigger bore.  Excuses make it go down easier, and supping a motor up is never a letdown.
Offline canyoncarver
  • 'hacking is learning'
« Reply #433 on: Jul 01, 2018, 20:36:13 »
Right on!.  There's a strong chance I'll have to do the same when I get back into mine.  I look forward to the details of your build.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline doc_rot
« Reply #434 on: Jul 06, 2018, 05:35:16 »
Finally got the easy win I was looking for. New EBC single disk setup. Shaved 4 pounds off rotational mass and an additional 2.5 unsprung with the removal of the extra caliper. I bought a 12mm brembo MC to match. The fitment is super tight. less than 1mm on spoke/caliper and disk/fork leg. I'm digging the new look. Very interested to see how it feels.
« Last Edit: Jul 06, 2018, 05:47:22 by doc_rot »
Offline Pete12
« Reply #435 on: Jul 06, 2018, 08:27:03 »
Wow, that front wheel looks great, should be no problem pulling that bike up.
Offline beachcomber
  • TJ - Beachcomber
« Reply #436 on: Jul 06, 2018, 08:33:54 »
Venolia pistons - how much ?
My exhaust cam is off to be modded [ remove gear ] and will come back as an inlet !!!
Just waiting to get my new HD compressor and blast cabinet installed - then it's into engine mod mode !  ;D First job is to strip the new twin plug head down and get some blueprinting done. What do you guys use for valve springs ?
There WILL be two donkeys - one will be the Weber / NOS version and the second more long term [ money ! ] will be the blown version. Probably Turbo as the Eaton conversion will rely totally on the good grace of others for machining fab etc.
Offline doc_rot
« Reply #437 on: Jul 06, 2018, 13:20:54 »
I got them used from a member over at KZR for $150
stock springs. if I had a higher lift cam I would get some custom springs made by Kibblewhite.
Offline 1fasgsxr
« Reply #438 on: Jul 06, 2018, 13:25:35 »
Love the new set up.  Looks great.  That's about what I want on the 350F. The stock rotor on it is heavy.
Offline doc_rot
« Reply #439 on: Jul 06, 2018, 14:00:32 »
this rotor is about 2.5lbs lighter than the stock single.
