Author Topic: saving a 1980 KZ750 twin  (Read 71354 times)
Offline doc_rot
Re: saving a 1980 KZ750 twin
« Reply #170 on: Jul 18, 2016, 01:36:27 »
I ordered some bends from Cone Engineering and was kinda disappointed in the quality. Not much better than my crushed sand bent radius. and they had creases on the outside of the bend. The first bend of the header is very visible so I bought some bends from Colombia Mandrel and the quality was much nicer and 7 bucks cheaper a piece to boot!
My buddy Eric thought 2" would be too big for the collector so I dropped that down to 1.875". This meant there were no cheap collectors to be bought so i had a go at making my own.
I hammered open the ends of the primaries and then faced them on the disk sander before welding them together to try and keep stress out of the welds. It still took a good amount of bashing after to get it to fit up.I also ovaled the big tube slightly to help out the transition. I was super shaky welding this up for some reason so the welds arent my best, I probably should have done some practice beads first to get in the groove but you will never see these welds when the pipe is on the bike, so whatever. I also compressed the fork to make sure there would be plenty of clearance. next up is sand bending the second bends.
« Last Edit: Jul 18, 2016, 03:37:34 by doc_rot »
Offline WackoTie
« Reply #171 on: Jul 18, 2016, 02:11:25 »
Looks great man
Sent from my SM-G920P using DO THE TON mobile app
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #172 on: Jul 18, 2016, 17:10:28 »
Nice work on the collector. I used a 2-1 collector from cone eng on the 360 headers and they neglected to tell me about the little triangle filler pieces. I ended up welding it to the headers once, removing it and rewarding between the two header pipes from the inside since it was impossible to fill the voids. I'll just make my own next time.
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
Offline doc_rot
« Reply #173 on: Jul 18, 2016, 22:27:41 »
Thanks guys
Offline doc_rot
« Reply #174 on: Jul 20, 2016, 03:22:01 »
Guess they were worried about vibrations.
Offline canyoncarver
  • 'hacking is learning'
« Reply #175 on: Jul 20, 2016, 12:03:14 »
Ya think?  Lol.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
Offline jpmobius
  • where does this go?
« Reply #176 on: Jul 20, 2016, 12:13:09 »
Very important for the battery!  (somewhat less so for some of the new tech batteries)  Be glad you have all the bits - some are a pain to find and put everything back proper!
Mobius
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #177 on: Jul 20, 2016, 13:16:45 »
Try soaking those rubber bits in DOT3 brake fluid overnight. I had some pretty good results on the XL rubber parts. It doesn't make them look new but it gives them back some of their flexibility.
Offline jpmobius
« Reply #178 on: Jul 20, 2016, 14:43:08 »
good idea, but have a care.  Soaking any rubber parts in brake fluid (methyl salicylate (wintergreen oil) and acetone is better) can do wonders, but pretty easy to overdo, so keep a close eye on how long you soak.  Some parts can seem fairly immune, but some can expand and become ruined unexpectedly.  Methyl salicylate is better IMHO and does not eat paint like brake fluid.  Go cart guys use it to prep their tires so check out cart suppliers if you want some.  Can also be had at drug stores slightly altered and way more expensive but it still works.
Mobius
Offline doc_rot
« Reply #179 on: Jul 20, 2016, 16:53:39 »
I have used wintergreen oil on carb boots before and it works pretty good. Only the 4 bushings that hold the battery to the frame are in bad shape and they are still available from Kawasaki for a little over a dollar a piece. I looked up the bikes that use these bushings and its well over 100 models all the way to 2016. guess Kawasaki got their moneys worth out of those molds.
