Author Topic: 73 CB100 Tracker Build  (Read 15669 times)
Offline 45exmayor
Re: 73 CB100 Tracker Build
« Reply #31 on: Aug 17, 2015, 19:13:02 »
Depending on how you wire the flashers you may need this diode https://www.superbrightleds.com/search/motorcycle-accessories/diode/. It goes in the wiring from the blinkers to the indicator light on the speedo.  Without the diodes the power will feed backend all four blinkers will flash at once.  If you need it I will postman drawing of the circuit. Also, it might be simpler to wire using a 2 pole relay that just has power in and signal out.  Wiring takes more time than anything else.
http://www.dotheton.com/forum/index.php?topic=66379.
'71 CB100/125
'02 monster 620 (sold)
'66 Triumph T100SC(sold)
Offline 45exmayor
« Reply #32 on: Aug 17, 2015, 19:29:07 »
I wired mine like this  used triple female terminals for my project. http://www.cycleterminal.com/bullet-terminals.html
Since I was doing a complete rewire I got a crimper. It was slow going but I ended up,with all new terminals and each wiring run is only as long as it needs to be. My here are no splices to fail later
« Last Edit: Oct 07, 2015, 19:03:08 by 45exmayor »
'71 CB100/125
Offline trek97
« Reply #33 on: Aug 17, 2015, 19:55:25 »
sparckmoto relay is less than half the price + the turn diode thingy + you will help feed a fellow DTT-ers children at christmas time.
« Last Edit: Aug 17, 2015, 19:57:16 by trek97 »
Offline travisvisual
« Reply #34 on: Aug 17, 2015, 21:03:48 »
Perfect, that makes sense. Just saw the "Ignition Coil or Headlight Subharness" on Sparck moto, is that something i should have as well?
Offline trek97
« Reply #35 on: Aug 17, 2015, 21:42:33 »
not exactly sure bout the sub harness but you will have to email matt specifically about the turn signal diode.  he dont advertise it on the site.
Offline Roots265
  • Mmmmm Vending Machine Hotdogs.
« Reply #36 on: Sep 08, 2015, 18:13:58 »
 Hey Bud
great build. im actually building one of these little machines at the moment too. (just started really) see topic http://www.dotheton.com/forum/index.php?topic=65546.0
what coil are you going to run with the 12V system?
im going to run a Oregen Moto battery eliminator and reg/rect. ill see how the standard generator handles this and maybe upgrade later to a ricks high output unit?
cheers
Adam
If a Jobs worth doing.
Its worth doing Twice.
Offline sleventynineR
  • Life in slow motion at 110 mph
« Reply #37 on: Sep 08, 2015, 21:49:11 »
Cool bike, I got a 70 that's in the works.
crtl+alt+delete yourself
7L9R
« Reply #38 on: Sep 22, 2015, 18:20:52 »
Thanks Adam...
I went with a coil from a YAMAHA XT600, it was suggested to me from Sparck Moto. I bought their 12volt reg/rect too. I bought a used cb350 stator and it fit right in, just using the stock plug. That's what i am currently working on now. Looking for lums/wire harness to really move any further.
Not sure if the lil stator can pump enough juice to eliminate battery but i really don't know.
Ill check out your build!
Hey Bud
cheers
Adam
« Reply #39 on: Oct 07, 2015, 16:49:32 »
Its been a little bit, but I have some things to report!
Got a bunch new parts it!
Bars
Speedo
New Brake & Clutch Levers
New Handle bar controls
Head light
rear shocks are on the way
And a bunch of electrical stuff for my 12volt conversion
I installed the 350 stator, it was super tricky to get the oil plug to fit on from the original cb100 stator. It makes me feel a lot better about it, i know some people just used some sort of silicon but if i need to open it up for any reason I would like that option. Just need to solder it up to the stock plug.  Been really sitting on electrical to be honest, want everything to be done right.  Finally made an oder to cycle terminal and got what I needed.
Now i just need to wire it all up and make sure she works, then onto the next phase!
Oh! also found a paint chip for the frame, its in one of those photos.
Pulled out my old tail light that I had on my Sport Classic, going to get that re wired as well.
