Author Topic: Long awaited CB200 Build  (Read 20455 times)
Offline Tim
  • Administrator
    • DO THE TON
Re: Long awaited CB200 Build
« Reply #100 on: Jan 21, 2018, 17:01:26 »
The battery location looks cool, and I'm confident given your attention to detail you're thinking about things like this, but consider how you're going to connect/disconnect the terminals.
Make sure you have clearance for the bolts and tool.
That and ventilation for cooling the electrical components.
Offline bex
« Reply #101 on: Jan 21, 2018, 17:18:03 »
Yes, it needs some thinking about to get it right. The cowl will be removable and so the battery will be able to be lifted out worse case scenario (fixed to pan rather than cowl), but it should be possible to leave it all on too
Offline bex
« Reply #102 on: Mar 16, 2018, 15:39:21 »
Got some new Keihin PE22 carbs delivered this week. The plan was to bore the originals but apparently there isnít enough metal there, I had been warned this was likely the case (Iím not doing the more complex engine mods myself) so need to find some adaptors for these. Anybody know of any that will fit?
Offline bex
« Reply #103 on: Mar 18, 2018, 18:32:54 »
Collected some parts from the specialist who has overbored the barrels +1mm, beautifully smooth honed finish.
The air intake ports have been machined out and resin deposited in there and reshaped for a smoother air flow.  He used resin in the end as adding metal wasnít sticking, clever stuff.
Boring stuff going on in the background includes taping up engine casings for painting, now that the temperature has gone up at bit. At least it did briefly.
Offline bex
« Reply #104 on: Mar 26, 2018, 11:49:01 »
Offline Alex jb
« Reply #105 on: Mar 29, 2018, 16:33:12 »
 Nice work,
Did you match the port with the carb inlet size?
I have worked my 200 head quite a bit for smoother more continuous cross section flow, but havenít matched the carbs yet
Offline bex
« Reply #106 on: Mar 29, 2018, 18:29:20 »
Yes - well, I didnít, but the guy doing the specialist engine work did/is.
Offline bex
« Reply #107 on: Apr 01, 2018, 19:04:23 »
Thatís my Easter weekend sorted
Offline bex
« Reply #108 on: Apr 09, 2018, 08:10:48 »
So the upsized Keihins, along with the original manifolds, have now been machined to match the new gas flowed intake ports ...
Offline bex
« Reply #109 on: Apr 10, 2018, 11:06:32 »
Just got my stator back from rewinding, looks great.
Before:
After:
And a bit of both: :D
