Author Topic: Brodie's Bastard BSA  (Read 23953 times)
Offline Brodie
  • Gold Coast, Queensland
Re: Brodie's Bastard BSA
« Reply #30 on: Jan 12, 2016, 21:53:40 »
Would have to move the studs in a bit. But the hole would end up elongated
My 2 plans involve finding a big bore cylinder with wider bolt pattern or running the flat head and using a 5 speed gearbox with small rear sprocket.
I would prefer the first. But I think building a plate to fit around the cylinder base and having that braised on, the correct bolt spacing drilled might be the go. Just worried about braise strength.
Offline Hurco550
« Reply #31 on: Jan 12, 2016, 22:38:58 »
You could loctite in aluminum studs then machine new holes without welding. I've done that a bunch on different equipment. Never a bike (for full disclosure) but it should work all the same
~ bradj
Offline Tune-A-Fishİ
« Reply #32 on: Jan 12, 2016, 23:07:43 »
cant the cast be cad welded shut and re drilled? take some filings and get it tested mang.
Offline xb33bsa
« Reply #33 on: Jan 13, 2016, 10:40:17 »
the cast iron can be cast iron welded, but you need to find that guy ,a real qualified expert
,material can be added and built up .its an oxy-acetelyne process ,requires careful, even ,slow,hi temp preheat and slow cooldown in the oven as well
Offline xb33bsa
« Reply #34 on: Jan 13, 2016, 10:47:09 »
ok i see how the hole misses now.a slightly elongated hole is not a big issue as long as you can ad a heavy washer that will not distort
the other minor issue is to have the barrel clocked correctly and extra dowel or 2 would suffice
but those holes in the barrel are a basic very easy job for a qualified EXPERIENCED well know expert cast iron jockey
these guys are used to really broken shit,usually antique  that cannot be replaced ,a nice clean easy to see barrel job like that , a walk in the park
« Reply #35 on: Jan 13, 2016, 10:56:32 »
Why not heat, nickel rod weld and bury in hot sand... loooks like it will all be under the jug so wont see the chiney weld.
I dont see threads so must have nuts backside no? maybe turn the jug just a few deg and fill the holes with lead leaving it a few thou proud topside to ease off with a file. Push rods wont mind a slight angle and tubes can be cussum fit with some leather seals soaked in hot wax.
Offline xb33bsa
« Reply #36 on: Jan 13, 2016, 12:48:07 »
nikel is for tempory "fixes" it aint no good the problem is the weld can easily be too hot which fucks with the carbon in the iron making a hard as spot, right where it needs to be, drilled agin :-[
i bet he could get it iron welded ,and faces machined for under 300 that would be money well spent
Offline Hurco550
« Reply #37 on: Jan 13, 2016, 13:17:18 »
I'm still thinking modified aluminum cases. They are aluminum right? Much easier to work with than modding cast iron
~ bradj
Offline xb33bsa
« Reply #38 on: Jan 13, 2016, 14:41:05 »
nevrer to be a bsa agin  :'( :'( by god you dont buggger as first wirst  ,bah ! the barrels are expendable
Offline Hurco550
« Reply #39 on: Jan 13, 2016, 14:53:03 »
Lol I have little morals when it comes to bikes. Even bsa. To me, better to be modified and ran than not touched and sitting. There is a line though. If it were a Vincent or something nah,  but a modded thumper bsa... weld er up. Of course, my opinion only.
~ bradj
