Honda OEM fuel cap
sprocket2cog
Ive managed to find a honda fuel cap that fits the bike, took a few weeks of searching part numbers and measuring sizes etc until i found "the one"..
the magic number for the non locking fuel cap is
17620-402-010
surprisingly it isnt actually listed for the honda CG models
it fits alot of bikes from trail bikes and road bikes
heres a link to the partzilla page, scroll down and it will list all the bikes it fits so you can cross ref them on ebay etc.
http://www.partzilla.com/parts/detail/honda/HP-17620-402-010.html
some models it fits
1977 FL250 A FUEL TANK + FUEL VALVE
1984 FL250 A FUEL TANK + FUEL VALVE
CB92 A FUEL TANK
CB77 A FUEL TANK
CB92 A FUEL TANK
CL72 A FUEL TANK
CB450 A FUEL TANK
CB450K1 A FUEL TANK + SEAT
CB450K2 A FUEL TANK + SEAT
CL72 A FUEL TANK
CL77 A FUEL TANK
S90 A FUEL TANK
CA160 A CA160 FUEL TANK
CB450 A FUEL TANK
CL72 A FUEL TANK
CL77 A FUEL TANK
S90 A FUEL TANK
CB450 A FUEL TANK
CB450K1 A FUEL TANK
CB450K2 A FUEL TANK
CL125A A FUEL TANK
CL450 A FUEL TANK
CL450K2 A FUEL TANK
CL77 A FUEL TANK
CL90 A FUEL TANK
S90 A FUEL TANK
SS125A A FUEL TANK
CA175 A CA175 FUEL TANK
CA175K3 A CA175 FUEL TANK + SEAT
CB350 A FUEL TANK
CB350K2 A FUEL TANK + FUEL VALVE K2
CB450 A FUEL TANK
CL125A A FUEL TANK
CL175 A CL175 FUEL TANK + SEAT
CL175K3 A CB-CL175FUEL TANK
CL175K4 A CL FUEL TANK + FUEL VALVE
CL175K7 A CL FUEL TANK + FUEL VALVE
CL350 A FUEL TANK
CL350K2 A FUEL TANK + FUEL VALVE K2
CL450 A FUEL TANK
CL450K2 A FUEL TANK
CL77 A FUEL TANK
CL90 A FUEL TANK
S90 A FUEL TANK
SS125A A FUEL TANK
CB175K3 A CB-CL175FUEL TANK
CB175K4 A CB FUEL TANK + FUEL VALVE
CB175K5 A CB FUEL TANK + FUEL VALVE
CB175K6 A CB FUEL TANK + FUEL VALVE
CB175K7 A CB FUEL TANK + FUEL VALVE
CB350 A FUEL TANK
CB450 A FUEL TANK
CL125A A FUEL TANK
CL175K5 A CL FUEL TANK + FUEL VALVE
CL175K6 A CL FUEL TANK + FUEL VALVE
CL350 A FUEL TANK
CL450 A FUEL TANK
CL450K2 A FUEL TANK
CL70K1 A FUEL TANK
CL70K2 A FUEL TANK
CL70K3 A FUEL TANK
CL90 A FUEL TANK
S90 A FUEL TANK
SL90 A FUEL TANK
SS125A A FUEL TANK
CB100 A FUEL TANK + FUEL VALVE
CB100K1 A FUEL TANK + FUEL VALVE
CB100K2 A CB100 FUEL TANK + FUEL VALVE K2
CB350 A FUEL TANK
CB450 A FUEL TANK
CL100 A FUEL TANK + FUEL VALVE
CL100K1 A FUEL TANK + FUEL VALVE
CL100K2 A CL100 FUEL TANK + FUEL VALVE K2-S3
CL100S3 A CL100 FUEL TANK + FUEL VALVE K2-S3
CL350 A FUEL TANK
CL450 A FUEL TANK
CL450K2 A FUEL TANK
CL70K1 A FUEL TANK
CL70K2 A FUEL TANK
CL70K3 A FUEL TANK
SL100 A FUEL TANK
SL100K1 A FUEL TANK
SL100K2 A FUEL TANK
SL100K3 A FUEL TANK
SL175 A FUEL TANK + FUEL VALVE
SL175K1 A FUEL TANK + FUEL VALVE
CB350 A FUEL TANK
CB450 A FUEL TANK
CL350 A FUEL TANK
CL450 A FUEL TANK
CL450K2 A FUEL TANK
CL70K1 A FUEL TANK
CL70K2 A FUEL TANK
CL70K3 A FUEL TANK
SL100 A FUEL TANK
SL100K1 A FUEL TANK
SL100K2 A FUEL TANK
SL100K3 A FUEL TANK
SL125 A FUEL TANK + FUEL VALVE
SL125K1 A FUEL TANK + FUEL VALVE
SL125K2 A FUEL TANK + FUEL VALVE
SL70 A FUEL TANK
SL70K1 A FUEL TANK
CB350 A FUEL TANK
CB450 A FUEL TANK
CL350 A FUEL TANK
CL450 A FUEL TANK
CL450K2 A FUEL TANK
CL70K1 A FUEL TANK
CL70K2 A FUEL TANK
CL70K3 A FUEL TANK
SL100 A FUEL TANK
SL100K1 A FUEL TANK
SL100K2 A FUEL TANK
SL100K3 A FUEL TANK
1983 CB125S1 A FUEL TANK
1983 CB125S2 A FUEL TANK
1983 XL250 A FUEL TANK
1983 XL250K1 A FUEL TANK
1983 XL250K2 A FUEL TANK
1984 CB125S A FUEL TANK
1984 CB125S1 A FUEL TANK
1984 CB125S2 A FUEL TANK
1984 XL250 A FUEL TANK
1984 XL250K1 A FUEL TANK
1984 XL250K2 A FUEL TANK
1985 CB125S A FUEL TANK
1985 CB125S1 A FUEL TANK
1985 CB125S2 A FUEL TANK
1985 XL250 A FUEL TANK
1985 XL250K1 A FUEL TANK
1985 XL250K2 A FUEL TANK
1990 CB125S A FUEL TANK
1990 CB125S1 A FUEL TANK
1990 CB125S2 A FUEL TANK
How does it retain the fuel when the tank is full?
http://www.ebay.com.au/itm/Honda-XR75-SL70-Fuel-Tank-Cap-OEM-Vintage-17620-402-010-/181767192342?hash=item2a522b3f16
A bit better then stock but if i lean the bike over it drips a little bit.
but no where like the stock one was.
thats the same seller i got mine from :D
Replaced the fuel cap washer with Honda OEM part. The Skyteam fuel cap does not seal and is well known to leak across the Ace community (as well as the fuel tank and decals).
The Honda washer is marginally thicker than the Skyteam OEM. To allow the fuel cap to close I increased the curve on the leading edge of the locking tongues only marginally. Note: I did not bend the tongues along the horizontal axis.
All good and very happy.
Honda Fuel cap gasket (p/n 17632-176-771) $11.75
Sorry for the thread resurrection, but i thought i would keep it all in one thread.
I have tried several caps, and several seals including the Honda ones, and the tank is still yellowed with dried fuel. Most of the time i couldn't even get the cap to close with the Honda seals, and if I did i looked like an idiot at the pump struggling for 10 minutes each time (The key needing to be in it makes it harder to push down..)
However tonight i think i sorted it. I was speaking to a guy with a Royal Enfield, and he said they suffer similar issues, he suggested I try cork rubber gasket. So i ran down to the local Auto store and grabbed a 1.6mm thick sheet for $9 bux or something. First I tried to make a custom gasket, And that didn't work too well (either too fat or too slim), so I put the Honda one back on, then I cut a tiny O ring (2-3mm in width), one that would fit under the outer edge of the Honda gasket. Some shaking, hard braking, cornering and not a single drop spilled.
