Last summer I got this '76 CB750F. It ran pretty well when I got it, with the exception of one of the carbs flooding. And was in really good shape considering what I bought it for. It is my first project bike, and has been coming along slowly since I brought it home.
I have been spending lots of time on the site, and it has been great seeing all the bikes that everybody is working on. I figured that as much time as I spend looking at the site I better post something about what I have been up to.
Here is the bike when I brought it home.
<img src="http://lh4.ggpht.com/_vZZxEy5HMKM/SWmUpzxLEUI/AAAAAAAABPY/ZxSZ_AZGF3E/s800/cb750f-1.jpg" />
The first thing that had to go was the Windjammer. I labeled all of the wiring before disconnecting everything, and then pull the it all off. My daughter helped. A guy restoring a goldwing bought it from me and made my bike a little more of a bargan ;D
<img src="http://lh5.ggpht.com/_vZZxEy5HMKM/SWmUq7gwScI/AAAAAAAABPo/OlaybmUKfzY/s800/helper.jpg" />
I took off the stock bars to replaced them with clubmans. I still wanted to run the wires inside the bars, so I made a make-shift template from the original bars by taping over the wiring holes, and using a Shapie to black out the tape over the hole. Once the tape was blacked out, I used an exacto knife to trim out the hole and tranfered the tape to the clubman bars. This gave me the size and location to drill the holes in the new bars. (I did a pretty crappy job of drilling, but that was not the fault of the template)
<img src="http://lh5.ggpht.com/_vZZxEy5HMKM/SWmUqNzTjgI/AAAAAAAABQM/Ro6cJmbetzE/s800/drilling_bars.jpg" />
Running the wires was not so fun. I got the right hand control wires through all at once (in the shrink tubing). I tied a shoelace around the wires, fed the string through, and the pulled and pushed the wires through. There was silicone spray involved, as well as a lot of swearing.
The left hand controls were a bigger hassle because there are more wires (11 I think) to get through. I could not get the wires to feed though all at once, so I had to cut the shrink tube and do the wire individually. I tried a lot of variations to get all the wires through (very frustrating), and the best solution that I found is as follows:
I would recommend silicone spray to help get the wire to run smoothly through the bars. BUT keep in mind that the silicone spray does bad things to any masking tape labels that you may have used to identified your wires before disconnecting them. That part was the cherry on top.
Since the headlight went with the fairing, I needed to replace it. I got a lucas style shell off ebay. Compared to the stock shell, it is huge. My daily rider is a 04 triumph Bonneville, so I guess that is were my taste for large headlights comes from. Anyway, there is lots of room to stuff wires in there so that will be handy.
<img src="http://lh4.ggpht.com/_vZZxEy5HMKM/SWmUqm8UR8I/AAAAAAAABPk/6eHfRGEYphE/s800/headlight.jpg" />
I also got an airtech seat off ebay. I thought about going with a round seat cowl, but I thought the duck bill would work better with the tank shape. Here is a quick look at what the combo would look like.
<img src="http://lh6.ggpht.com/_vZZxEy5HMKM/SWmUratzwEI/AAAAAAAABPs/lfYVavGMPnw/s800/moch_up.jpg" />
The latest work that I have done is to get the carbs off, and remove the airbox. The Carbs were really stubborn to get off. Thanks to some guidance from the help forum, I managed to get the carbs off with some heat, using the wood handle of a rubber mallet for leverage to get some play, and once I got them loose I squeezed the airbox out the right side. After that they came out no problem.
<img src="http://lh6.ggpht.com/_vZZxEy5HMKM/SWmUqYyfV8I/AAAAAAAABPg/EbywKjX6EOQ/s800/engine.jpg" />
When I first started the project I was on the fence if I should take everything down to frame. I talked myself out of it, and thought I would just keep it simple as this was my first project. After getting myself to this point, and being inspired by the other bikes on the site, I have decided that I might go all in. I got the bike to learn on, so what is the point of half assing it?
So the next step is getting everthing labeled, photographed, off the frame, and in bags.
It will be my first try at it, but I also plan on doing a bunch of polishing on the engine and forks, so I have been paying close attention to the 1981 Yamaha XS 650 Special thread (great work cretin, and a shame that you stripped that tank ). Lots of helpful info in there. One question, JRK said for polishing start by sanding with 400 - 600 - 800wet - 1000wet - 1500wet - 2000wet. Are you doing the sanding by hand, by dremel, or by wheel? I got my hands on a buffing wheel and dremel, and if I can take care of the sanding with one of those it would be nice to save the time.
I will keep posting as the build continues. Things may be a little slow (I have a 4 month old daughter that tends to keep me out of the garage), but I will post when I can.
Thanks for all the helpful posts and projects. They have been loads of fun to watch.
- Cut the shrink tube so all of the wires are lose. You can play with how high up you want to cut, but I found that sleeve got in that way so I cut it pretty high
- Next run a string through the bars. Something thin, but strong enough to hold up to a lot of pulling and rubbing inside the bars.
- Tie the end of the string to the first wire that you want to pull through. Then tie a second string to the same wire so that once the wire is all the way through the bars you will have a string in the bars to pull the next wire through with. (The first time you do this, it may save you some time to pull multiple wires through, as there will be lots of room in the empty bars. As you repeat the steps it will be harder to run the wires through and you will need to pull the wires one at a time)
- Repeat this until you have all of the wires through
