Author Topic: Maritime's new GL - 2UP Distance eater  (Read 48505 times)
Offline JustinLonghorn
Re: Maritime's new GL - 2UP Distance eater
« Reply #20 on: Feb 04, 2016, 21:35:48 »
Now you just need a more permanent mount. Even better if it is removable.
Into The Sunset, CB750 build
TT500 the Animal
Offline Brodie
  • Gold Coast, Queensland
« Reply #21 on: Feb 04, 2016, 23:16:11 »
How about ice climbing spikes for around boots, then just modify it into a shifter.
« Last Edit: Feb 04, 2016, 23:17:45 by Brodie »
Offline Maritime
« Reply #22 on: Feb 05, 2016, 10:20:40 »
Brodie that is pretty close to what I am going to do. I am going to use a strap on ice tread called gripons then remove the little studs and attach the plate to them, they go over the toe and heal of the boot. There is an instructable an engineering student did for a paper in school taking the screw on version and improving it to make it removable.  I'll post up pics when I do it. I am pretty stoked it is going to work!
Offline Maritime
« Reply #23 on: Feb 05, 2016, 10:26:45 »
I'll be using a set of these.  With an angle bracket or large washer or whatever I can find that is a good shape and fit at the hardware store. will also be plasti-dipping it for some grip.
Offline Maritime
« Reply #24 on: Feb 05, 2016, 10:29:06 »
like this
Online irk miller
« Reply #25 on: Feb 05, 2016, 10:30:49 »
That's why I was suggesting the bicycle toe clips.  They come with places to mount the plate and everything.
Offline cxman
« Reply #26 on: Feb 05, 2016, 12:02:45 »
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline Maritime
« Reply #27 on: Feb 05, 2016, 13:04:36 »
LOL yep Murray I would be able to corner supermoto style with sparks!
Kamn
  • Guest
« Reply #28 on: Feb 05, 2016, 13:15:57 »
Actually something like this is very easily doable......coming off the end of the shifter??
Or the sparky shoes would always make for a great show!
Online irk miller
« Reply #29 on: Feb 05, 2016, 13:18:36 »
What I was thinking is instead of attaching it to the shifter, a shifting plate gets attached to the toe clip. That angle bracket could be straightened out, or one could even be welded to it.  There is a strap not shown that goes through the loop at the top and wraps around your boot to hold it on.
