Author Topic: Maritime's new GL - 2UP Distance eater  (Read 48479 times)
Offline The Jimbonaut
    • Lost Apostle
Re: Maritime's new GL - 2UP Distance eater
« Reply #450 on: Jun 11, 2018, 10:41:00 »
Wait, is the voltmeter the only dial on your bars?  Brilliant!
Excuse me sir do you know how fast you were travelling?
No officer, but my battery's in excellent shape  8)
Offline Maritime
« Reply #451 on: Jun 11, 2018, 10:52:10 »
Ha, That'd be funny but no I have a cheapo china bay digital tach speedo temp gauge, frenched into the tank where the old fuel/temp/ volt meters used to be. The multi gauge didn't have the volt in it and this old girl can drain a battery when stuck in traffic for to long so I like to have the meter to either shut her off or rev her a bit to increase charging when stuck. She charges just fine 3k rpm and up. You can see it in this pic, along with the doughnuts from the gas station and the cane I was using to walk on the cabot trail run LOL
« Last Edit: Jun 11, 2018, 10:59:10 by Maritime »
    • Lost Apostle
« Reply #452 on: Jun 11, 2018, 10:56:28 »
Gotcha!
Is the charging issue common with all older GL's?  Hope you're riding soon mate, heck of a weekend here and great to get out amongst it.  The new fairing on your bike looks great!
Offline Maritime
« Reply #453 on: Jun 11, 2018, 11:25:21 »
Gotcha!
It's like that on a lot of old Hondas but the first gen GL's have a lot of draw without a lot of Stator charge capacity. I've done all the recommended mods to help, and it only gets dicey if it sits and idles for 5-10 mins or longer, I just like the meter to know when it gets close to battery killing levels, and that has only really happened to me a couple of times, both time on a hot day with bad traffic due to accident on freeway in the states so sitting and the fan comes on and starts to drain down the batter cause I only get like 13.5V at idle instead of the 14.5-15 at 3 so it uses the battery to run engine and fan together and starts draining it.
Offline cbrianroll
« Reply #454 on: Jun 11, 2018, 12:01:50 »
There is a alternator mod if you haven't seen it. Not sure if it's all models.
Offline Maritime
« Reply #455 on: Jun 11, 2018, 16:40:20 »
I just did a run from home to work on the freeway, fairing is just enough to cut most of the buffeting. the windscreen was taller and cut 100%, this does about 80% so unless I am doing 1000 miles in a day at 80 mph it will do. Cuts 100% at 55-60 mph so its good. The volts never dropped below 14V on the meter with all the lights on the whole ride, and I let it idle for 5 mins and stayed above 14 with the lights all on so I think I am good, I did something to the stator when I had the engine out back in 2009 but not sure now what.
The fan didn't kick in though as it isn't hot enough here yet to need it. that will tell.
Offline Maritime
« Reply #456 on: Jun 11, 2018, 18:06:57 »
Ride home was good. Everything is gtg for Laconia. Also can report the front is also now straight so the alignment worked.
Offline Maritime
« Reply #457 on: Jun 24, 2018, 16:03:14 »
So Laconia trip went well except for sone hiccups in the rain and some backfiring. Ordered a new acv valve and just swapped it. Original valve looked ok but there was a missing oring. Add to that my airbox to intake gaskets fell into 4-5 pieces and I think we figured out some issues. Jumped on Randakks site and ordered a replacement gasket. When it areives ill button her all back up and test ride again
