Author Topic: Vapor Blasting  (Read 6231 times)
Offline Babsworthy
Re: Vapor Blasting
« Reply #20 on: Mar 13, 2016, 00:54:29 »
How long would I expect the process to take shipping from the US?
Sent from my SM-G900V using Tapatalk
When all else fails, beat it with a hammer!
Offline NobleHops
  • Recovering geek
    • RestoCycle LLC - Vapor Blasting and Japanese Cycle Restorations
Re: Vapor Blasting
« Reply #21 on: Mar 20, 2016, 22:07:25 »
T-A-F, you rock.
Babs, sorry I am just seeing this. Where are you at? Can't glean that from your profile. My turnaround times are about 2 days in shop, the rest is just nominal shipping speed.
N.
Nils Menten * Tucson, Arizona, USA *
I do vapor blasting! http://www.restocycle.com
Ikon shocks for your sweet ride! https://www.ikonshocksusa.com/
Proud sponsor of DO THE TON
Offline NobleHops
  • Recovering geek
Re: Vapor Blasting
« Reply #22 on: Mar 26, 2016, 19:53:20 »
Tune-A-Fish's latest project: a 74 XL 350
(magnesium - tricky!)
Next!
Offline Tune-A-Fishİ
Re: Vapor Blasting
« Reply #23 on: Mar 27, 2016, 03:07:30 »
So fresh
Offline NobleHops
  • Recovering geek
Re: Vapor Blasting
« Reply #24 on: Mar 28, 2016, 18:32:19 »
So fresh
Thank you VERY MUCH for the project, much appreciated.
N.
Offline NobleHops
  • Recovering geek
Re: Vapor Blasting
« Reply #25 on: May 11, 2016, 12:06:39 »
Here's what's new!
Two-cycle cylinder heads. This happens more often than you'd think: Guys bead blast their parts and then wish they had not. I can fix this but I sometimes spend a bunch of extra time cleaning because they don't mask and plug the parts as carefully as I do.
This was along the lines of a resurrection. I think this motorcycle was parked UNDER the barn:
Sure, we speak car!
Old trick parts:
8 Kawasaki engines? Sure, send 'em!
Vintage motocross!
"Careful with my just-honed cylinder!" Yes, we are careful :-)
Brakes!
Carbs!
A "Triumph-ant" army"
Sure, we can fix that. And that, and that, and that.
OK, back to work!  :-)
Offline NobleHops
  • Recovering geek
Re: Vapor Blasting
« Reply #26 on: Jul 09, 2016, 13:34:13 »
Cool vapor blasting project in the shop here at RestoCycle this week - engine parts from a 1959 R50/2. Here are a few thousand words on the subject :-)
Shiny side up!
N.
Offline NobleHops
  • Recovering geek
Re: Vapor Blasting
« Reply #27 on: Jul 26, 2016, 01:07:42 »
I really do love working on CBX engines. They keep us hopping, but the metal is gorgeous and after all, it's a CBX! :-)
Offline NobleHops
  • Recovering geek
Re: Vapor Blasting
« Reply #28 on: Sep 01, 2016, 13:27:25 »
Update time from RestoCycle! So on the other side of the shop we restore and build vintage and custom motorcycles, which is what led us into the vapor blasting work in the first place.
We recently finished a nut-and-bolt restoration of a 75 Kawasaki Z1-900 that was a total blast. This bike went down to itty bits, and was completely restored - including new transmission parts, bearings, clutch, honed for the high compression big-bore pistons it wears, and a brand new head with Kibblewhite valves, springs, keepers. Carbs were also rebuilt. The fork has RaceTech internals and new tubes, the rear some nice Ikon shocks and roller swingarm bearings, and everything else in between is new or was totally refurbished to as-new condition. There is fantastic reproduction parts support for these bikes, and that is where the signature 4-into-4 exhaust came from, along with the gorgeous bodywork, faithfully reproduced by craftsmen in Japan.
It was so fun to build this bike I bought another and it is awaiting its turn :-).
Where we started. It was a lot worse than it looked at this point.
Torn down, frame powdercoated, up on its stand and about to get reassembled.
Fork apart, waiting for parts from RaceTech, and installation of new springs and gold valves.
Wheels about to be relaced, new spokes, strips, and bearings. Hubs freshly vapor blasted.
New wiring harness, into replated brackets. All the wiring was carefully renewed, cleaned, retaped, made perfect.
Engine torn down to little bits: We found pitting and worn valve guides so the head got totally redone, cylinders honed. Also found bad transmission parts and bearings, all repaired or replaced. Oil pump rebuilt, clutch hub bearing, springs, discs replaced. Many new cam chain tensioner parts. This beast is actually a 1075 and has high-compression pistons to boot. It boogies :-).
My brother could not resist the urge to port it, "just a little". Ok, ok. :-)
We replated and reused all the original fasteners.
The entire engine was of course vapor blasted and looks new.
The build - so many details!
And done. Took it out for a maiden cruise a week or so ago, and it is running great, is a total blast to ride. Will deliver this to my friend/customer in Switzerland in the spring, just as their riding season gets started. This bike will be ridden and loved.
We have more projects and news to share, coming soon. Thanks for checking in.
Offline canyoncarver
  • 'hacking is learning'
Re: Vapor Blasting
« Reply #29 on: Sep 01, 2016, 17:41:00 »
Geez, that looks like it just came off the factory floor!   Beautiful work.
