Author Topic: Ducati Mobster  (Read 19530 times)
Offline focusinprogress
  • City Limit Moto:Parts-Service-Apparel (716)8038606
    • City Limit Moto
Re: Ducati Mobster
« Reply #90 on: Sep 11, 2017, 16:02:58 »
killer stuff going on here. Keep the pics coming.
For all your gear needs, check out CityLimitMoto.com
DTT10 code for 10% off at checkout
Offline 1fasgsxr
Re: Ducati Mobster
« Reply #91 on: Sep 11, 2017, 16:06:39 »
I hope those exhaust cans don't drag.. this thing is looking amazing!
Offline maxBetteridge
    • Max Betteridge design
Re: Ducati Mobster
« Reply #92 on: Nov 18, 2017, 20:35:09 »
It's finished!
Here are the final things that needed doing.
One of the cans was quite damaged on the outside so I flipped the sleeve to hide the damage.
I had to waterjet some stainless straps which hung the cans at the right height and offset from the stock hanger.
Then just had to make the intermediate pipes to connect them up. I could've gone to an exhaust shop and hot some bends or at least some straight pipe to segment cut.. But I thought I'd try something different with the material I already had.
(BTW they're not supposed to be symmetrical!)
Since I couldn't transport the bike and I don't have a welder at home I had to use the 3D scan and CAD the pipes in Rhino and unroll the segments and waterjet them all connected so that when I rolled and bent them they should all align and match the angles in CAD. This meant I was able to tack them up at work without test fitting on the bike, then only test fitting them once they were welded up. It worked an absolute treat!
The paint was basically the only thing which I outsourced and I'm glad I did! The parts took I think 4x coats of clear just to get a flat surface to lay the basecoat on and then more clear.
A few weeks before I finished the bike I came across another custom Monster named the Mobster; I had always been treating Mobster as a bit of a working name for the bike but seeing another one come out with that name made the decision easy for me, the bike definitely needed a new name..
So here it finally is - the 'Flat White'
Full resolution photos are on my website:
http://www.maxbetteridgedesign.com
Check out the article on bikeexif:
http://www.bikeexif.com/ducati-monster-400-cafe-racer
Find me on instagram @max_betteridge_design
https://www.instagram.com/max_betteridge_design/
« Last Edit: Nov 18, 2017, 20:47:42 by maxBetteridge »
Offline stroker crazy
  • crazy as a fox
Re: Ducati Mobster
« Reply #93 on: Nov 18, 2017, 20:44:02 »
Well done indeed!
(also my favourite coffee)
Crazy
“Ride like the Wind” W.H.
Offline The Limey
  • Evil English Villain
Re: Ducati Mobster
« Reply #94 on: Nov 19, 2017, 10:51:52 »
That is gorgeous in every way
Offline hooligan998
Re: Ducati Mobster
« Reply #95 on: Nov 20, 2017, 00:52:12 »
That looks like you should be wearing a tuxedo while riding it.  Nicely done!
Offline cb250nproject
  • If you can make it better do so
Re: Ducati Mobster
« Reply #96 on: Nov 20, 2017, 01:46:39 »
Flawless
first cafe build was an incomplete learning experience, more of a test run for the real thing FRANKENHONDA II
Offline Popeye SXM
  • Also used for MX
Re: Ducati Mobster
« Reply #97 on: Nov 20, 2017, 13:10:15 »
Fabulous bike. Thank you very much for sharing, I have enjoyed watching all your great work. Inspiring
    • City Limit Moto
Re: Ducati Mobster
« Reply #98 on: Nov 20, 2017, 14:55:13 »
beautiful results.
Offline Coopacoopacoopa
Re: Ducati Mobster
« Reply #99 on: Nov 20, 2017, 15:16:22 »
Saw this on bikeexif and then realized the build thread was here! Stellar work sir!
