Author Topic: KZ 750 Twin - Two point zero  (Read 61801 times)
Offline irk miller
Re: KZ 750 Twin - Two point zero
« Reply #210 on: Nov 14, 2016, 19:48:03 »
Just go to Home Depot or Lowes and get insulation foam.  Pink at the Depot or blue at Lowes.  You get a hell of lot more for the price, and it sculpts better.  No need to go to a specialty industrial place and its much better than florist foam. Oftentimes, strand works better for complex shapes, especially when working over a buck, ie a mold (which is what the foam is).  You can also thin coat the surface of the foam with joint compound and sand it super smooth so you have a perfect surface.
Online jpmobius
  • where does this go?
« Reply #211 on: Nov 15, 2016, 00:47:04 »
Well that's an idea!  I'm going to have to try that sometime!
Mobius
Offline irk miller
« Reply #212 on: Nov 15, 2016, 10:05:47 »
If you want something that acts similarly, but is much stronger, there is a material called Aqua-resin.  It's a very opaque plaster-like material that gets very hard and has a similar cured hardness to fiberglass resin.  I've been using it to make castable positives for years.  It's nice because of it's hardness and zero toxicity.  Here's an example of a master made from insulation foam and Aqua-resin...
Online canyoncarver
  • 'hacking is learning'
« Reply #213 on: Nov 17, 2016, 16:41:12 »
What is the favorite for a release agent on molds when doing fiberglass?
Offline irk miller
« Reply #214 on: Nov 17, 2016, 19:45:56 »
I have a couple I use.
Honey Wax, which even McMaster-Carr sells...
And stuff called Mann Ease Release 200 or 300...
Offline clem
  • static fluff
« Reply #215 on: Nov 17, 2016, 22:03:48 »
Where do you find this stuff Irk?
Sent from my SAMSUNG-SM-G920A using DO THE TON mobile app
Offline doc_rot
« Reply #217 on: Nov 18, 2016, 00:52:00 »
Yeah the wax is a must. fills small holes in really well. I have been spraying PVA over that but any sulfur free mold release will work like what IRK posted. I have used straight up axle grease in the past with good, albeit messy, results.
Online canyoncarver
« Reply #218 on: Feb 20, 2017, 00:17:12 »
Snapshot of what I got done today.  Body filler is still in progress for the seat, it's pretty ugly at this point but I think it'll look fine when I'm done.  The seat pan is done and I'm happy with the mounting setup too.  Battery and electronics tray done.  I got the frame braces done tonight but there is still some cleanup I need to do.  My welding skills still need alot of practice and even my grinding could use some work but I'm happy with the progress.
Online advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #219 on: Feb 20, 2017, 00:30:56 »
Digging the seat, nice work.
